flashing probe in graphics display window
  • flashing probe in graphics display window
    Any idea why my probe is flashing in the graphics display window? I tried a search for this and nothing came up. My program begins with a tp20_2 by 30 then i enter in a loadprobe command to change to a tp20_1 by 20. I calibrated the probe then tried to measure an auto circle. The probe was about 1mm away from the surface it was trying to measure. Could the probe calibration file be causing this? HELP!
    I believe my problem is the same as the one is this thread. http://www.pcdmisforum.com/showthrea...middle+program
    If anyone has time, please take a look at my code. I am 100% sure that the 1by20 is a 1by20. no extensions. All of my hits off the cad model are about 1mm off and I am about to go insane. I'm trying everything I can to get this to work including calibrating it many times. Anyways, here is the code.
    PART NAME : 1209-3305-PF
    REV NUMBER : 4
    SER NUMBER :
    STATS COUNT : 1
    STARTUP =ALIGNMENT/START,RECALL:,LIST=YES
    ALIGNMENT/END
    MODE/MANUAL
    LOADPROBE/TP20_2X30
    MOVESPEED/ 80
    TOUCHSPEED/ 1.7
    TIP/T1A0B0, SHANKIJK=-0.0015, -0.0042, 1, ANGLE=-0.0633
    MAN_PLN_Z =FEAT/PLANE,CARTESIAN,TRIANGLE
    THEO/<0.9702,-0.6663,-0.4>,<0,0,1>
    ACTL/<7.3245,9.4962,-14.7071>,<0.0014764,0.0042441,0.9999899>
    MEAS/PLANE,3
    HIT/BASIC,NORMAL,<0.413,-0.3246,-0.4>,<0,-0.0000002,1>,<6.7669,9.8373,-14.7077>,USE THEO=YES
    HIT/BASIC,NORMAL,<1.593,-0.596,-0.4>,<0,-0.0000002,1>,<7.9473,9.5672,-14.7083>,USE THEO=YES
    HIT/BASIC,NORMAL,<0.9047,-1.0779,-0.4>,<0,-0.0000002,1>,<7.2595,9.0846,-14.7052>,USE THEO=YES
    ENDMEAS/
    MAN_LIN_X =FEAT/LINE,CARTESIAN,UNBOUNDED
    THEO/<0.5489,-0.0705,-0.543>,<0.9999989,0,0.0014811>
    ACTL/<6.9024,10.0909,-14.852>,<0.9999994,0.0011043,0>
    MEAS/LINE,2,WORKPLANE
    HIT/BASIC,NORMAL,<0.5489,-0.0705,-0.543>,<-0.0000063,0.999991,0.0042425>,<6.9023,10.0909,-14.8521>,USE THEO=YES
    HIT/BASIC,NORMAL,<1.4929,-0.0705,-0.5417>,<-0.0000063,0.999991,0.0042425>,<7.8464,10.0919,-14.8522>,USE THEO=YES
    ENDMEAS/
    MAN_LINY =FEAT/LINE,CARTESIAN,UNBOUNDED
    THEO/<3.0598,-1.154,-0.7989>,<0.0003501,0.9999909,0.004243>
    ACTL/<9.4141,9.0091,-15.107>,<-0.0007479,0.9999997,0>
    HIT/BASIC,NORMAL,<3.0598,-1.1539,-0.7989>,<0.9999988,-0.0003564,0.0014796>,<9.4141,9.0092,-15.107>,USE THEO=YES
    HIT/BASIC,NORMAL,<3.0601,-0.3432,-0.7955>,<0.9999988,-0.0003564,0.0014796>,<9.4135,9.8198,-15.107>,USE THEO=YES
    ENDMEAS/
    INTERSECT_PNT1=FEAT/POINT,CARTESIAN,NO
    THEO/<3.06,-0.07,-0.6668>,<0.9999989,0,0.0014811>
    ACTL/<9.4133,10.0937,-14.9795>,<0.9999994,0.0011043,0>
    CONSTR/POINT,INT,MAN_LIN_X,MAN_LINY
    MAN_ALIGN =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
    ALIGNMENT/LEVEL,ZPLUS,MAN_PLN_Z
    ALIGNMENT/ROTATE,XPLUS,TO,MAN_LIN_X,ABOUT,ZPLUS
    ALIGNMENT/TRANS,XAXIS,INTERSECT_PNT1
    ALIGNMENT/TRANS_OFFSET,XAXIS,-3.06
    ALIGNMENT/TRANS,YAXIS,INTERSECT_PNT1
    ALIGNMENT/TRANS_OFFSET,YAXIS,0.07
    ALIGNMENT/TRANS,ZAXIS,MAN_PLN_Z
    ALIGNMENT/TRANS_OFFSET,ZAXIS,0.4
    ALIGNMENT/END
    COMMENT/OPER,NO,PREPARE FOR DCC MODE!
    MODE/DCC
    CLEARP/ZPLUS,1.5,ZPLUS,0,ON
    MOVE/POINT,NORMAL,<1.5532,1.644,5.3689>
    DCC_PLN2 =FEAT/PLANE,CARTESIAN,TRIANGLE
    THEO/<0.9829,-0.6978,-0.3994>,<-0.0010207,-0.0016498,0.9999981>
    ACTL/<0.9829,-0.6977,-0.3996>,<0.0001764,-0.0026334,0.9999965>
    MEAS/PLANE,4
    MOVE/CLEARPLANE
    HIT/BASIC,NORMAL,<0.3538,-0.3076,-0.3994>,<-0.0010208,-0.0016496,0.9999981>,<0.3539,-0.3076,-0.3985>,USE THEO=YES
    HIT/BASIC,NORMAL,<1.4265,-0.447,-0.3984>,<-0.0010208,-0.0016496,0.9999981>,<1.4263,-0.4471,-0.3991>,USE THEO=YES
    HIT/BASIC,NORMAL,<1.6704,-1.0187,-0.3992>,<-0.0010208,-0.0016496,0.9999981>,<1.6701,-1.0189,-0.4006>,USE THEO=YES
    HIT/BASIC,NORMAL,<0.4813,-1.0175,-0.4003>,<-0.0010208,-0.0016496,0.9999981>,<0.4814,-1.0174,-0.4004>,USE THEO=YES
    ENDMEAS/
    DCC_LINX =FEAT/LINE,CARTESIAN,UNBOUNDED
    THEO/<0.419,-0.0712,-0.5293>,<0.9999994,0.0011014,0>
    ACTL/<0.419,-0.0812,-0.5297>,<1,0.0000324,0>
    MOVE/CLEARPLANE
    HIT/BASIC,NORMAL,<0.4189,-0.0712,-0.5304>,<-0.0011014,0.9999994,0>,<0.419,-0.0812,-0.5305>,USE THEO=YES
    HIT/BASIC,NORMAL,<1.6339,-0.0698,-0.5286>,<-0.0011014,0.9999994,0>,<1.6338,-0.0812,-0.5288>,USE THEO=YES
    ENDMEAS/
    DCC_LINY =FEAT/LINE,CARTESIAN,UNBOUNDED
    THEO/<3.0606,-1.1794,-0.5878>,<-0.0022506,0.9999975,0>
    ACTL/<3.0609,-1.1792,-0.588>,<0.0001888,1,0>
    MOVE/CLEARPLANE
    HIT/BASIC,NORMAL,<3.0606,-1.1792,-0.5896>,<0.9999975,0.0022506,0>,<3.0609,-1.1792,-0.5896>,USE THEO=YES
    HIT/BASIC,NORMAL,<3.0588,-0.388,-0.5862>,<0.9999975,0.0022506,0>,<3.061,-0.3875,-0.5863>,USE THEO=YES
    ENDMEAS/
    INTERSECT_PNT2=FEAT/POINT,CARTESIAN,NO
    THEO/<3.0581,-0.0683,-0.5586>,<0.9999994,0.0011014,0>
    ACTL/<3.0611,-0.0811,-0.5588>,<1,0.0000324,0>
    CONSTR/POINT,INT,DCC_LINX,DCC_LINY
    DCC_ALIGN =ALIGNMENT/START,RECALL:MAN_ALIGN,LIST=YES
    ALIGNMENT/LEVEL,ZPLUS,DCC_PLN2
    ALIGNMENT/ROTATE,XPLUS,TO,DCC_LINX,ABOUT,ZPLUS
    ALIGNMENT/TRANS,XAXIS,INTERSECT_PNT2
    ALIGNMENT/TRANS,YAXIS,INTERSECT_PNT2
    ALIGNMENT/TRANS,ZAXIS,DCC_PLN2
    ALIGNMENT/END
    MOVE/CLEARPLANE
    MOVE/POINT,NORMAL,<-5.5482,-0.3983,2.8754>
    TIP/T1A90B90, SHANKIJK=-1, 0.001, -0.0018, ANGLE=89.9196
    WORKPLANE/XMINUS
    CLEARP/XMINUS,-0.5,ZPLUS,0,ON
    MOVE/CLEARPLANE
    $$ NO,MOVE ORIGIN TO CORRECT LOCATION USING FACE_PLN, TOP_ZERO_LIN1 AND BACK_EDGE_ZERO
    TOP_ZERO_LIN1=FEAT/LINE,CARTESIAN,UNBOUNDED
    THEO/<0.024,-0.2321,-0.0023>,<0,-1,-0.0000182>
    ACTL/<0.0238,-0.2319,-0.0011>,<0,-1,0.0000523>
    MOVE/CLEARPLANE
    HIT/BASIC,NORMAL,<0.0245,-0.2321,-0.0023>,<0,-0.0000182,1>,<0.0242,-0.2319,-0.0011>,USE THEO=YES
    HIT/BASIC,NORMAL,<0.0236,-1.1265,-0.0023>,<0,-0.0000182,1>,<0.0234,-1.1266,-0.001>,USE THEO=YES
    ENDMEAS/
    BACK_EDGE_ZERO_LIN2=FEAT/LINE,CARTESIAN,UNBOUNDED
    THEO/<0.0276,-0.0042,-0.6367>,<0,0.0001753,-1>
    ACTL/<0.0271,-0.001,-0.6371>,<0,-0.0000652,-1>
    MOVE/CLEARPLANE
    HIT/BASIC,NORMAL,<0.0259,-0.0042,-0.6367>,<0,1,0.0001753>,<0.0255,-0.001,-0.6371>,USE THEO=YES
    HIT/BASIC,NORMAL,<0.029,-0.0039,-2.4956>,<0,1,0.0001753>,<0.0287,-0.0011,-2.496>,USE THEO=YES
    ENDMEAS/
    FACE_PLN =FEAT/PLANE,CARTESIAN,TRIANGLE
    THEO/<0.0012,-0.7299,-2.337>,<-0.9999981,-0.0015116,-0.0012403>
    ACTL/<-0.0045,-0.7311,-2.3271>,<-0.999999,-0.0010785,-0.0009445>
    MEAS/PLANE,4
    MOVE/CLEARPLANE
    HIT/BASIC,NORMAL,<-0.001,-0.3035,-0.6414>,<-0.9996216,-0.0271321,0.0045388>,<-0.0065,-0.3049,-0.6409>,USE THEO=YES
    HIT/BASIC,NORMAL,<-0.0004,-1.1706,-0.9511>,<-0.9996216,-0.0271321,0.0045388>,<-0.0054,-1.1722,-0.9508>,USE THEO=YES
    HIT/BASIC,NORMAL,<0.0047,-1.166,-4.207>,<-0.9996216,-0.0271321,0.0045388>,<-0.0022,-1.1675,-4.207>,USE THEO=YES
    HIT/BASIC,NORMAL,<-0.0372,-0.2799,-3.5098>,<-0.9996216,-0.0271321,0.0045388>,<-0.004,-0.2798,-3.5096>,USE THEO=YES
    ENDMEAS/
    PNT1 =FEAT/POINT,CARTESIAN,NO
    THEO/<0.0258,-0.0043,-0.0023>,<0,-1,-0.0000182>
    ACTL/<0.0254,-0.0009,-0.0011>,<0,-1,0.0000523>
    CONSTR/POINT,INT,TOP_ZERO_LIN1,BACK_EDGE_ZERO_LIN2
    FINAL_ORIGIN_A1=ALIGNMENT/START,RECALLCC_ALIGN,LIST=YES
    ALIGNMENT/LEVEL,XMINUS,FACE_PLN
    ALIGNMENT/TRANS,YAXIS,PNT1
    ALIGNMENT/TRANS,ZAXIS,PNT1
    ALIGNMENT/END
    MOVE/CLEARPLANE
    PNT10 =FEAT/CONTACT/SURFACE POINT,CARTESIAN
    THEO/<0.0185,-0.6437,-1.4631>,<-0.0031816,-0.9515605,-0.3074451>
    ACTL/<0.0182,-0.6458,-1.4638>,<-0.0031816,-0.9515605,-0.3074451>
    TARG/<0.0185,-0.6437,-1.4631>,<-0.0031816,-0.9515605,-0.3074451>
    SNAP=NO
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=YES
    SAMPLE HITS=0,SPACER=0
    AVOIDANCE MOVE=NO,DISTANCE=0
    SHOW HITS=NO
    PNT11 =FEAT/CONTACT/SURFACE POINT,CARTESIAN
    THEO/<0.028,-0.8483,-1.5293>,<0.0031816,0.9515605,0.3074451>
    ACTL/<0.0277,-0.8524,-1.5306>,<0.0031816,0.9515605,0.3074451>
    TARG/<0.028,-0.8483,-1.5293>,<0.0031816,0.9515605,0.3074451>
    SNAP=NO
    SHOW HITS=NO
    COMMENT/REPT,.[ITEM 84, M]
    DIM DIST1= 3D DISTANCE FROM POINT PNT10 TO POINT PNT11,SHORTEST=OFF,NO_RADIUS UNITS=IN,$
    M 0.2150 0.0100 0.0100 0.2174 0.0024 0.0000 ----#---
    MOVE/CLEARPLANE
    MOVE/POINT,NORMAL,<-1.3077,-0.2286,4.9645>
    LOADPROBE/TP20_1_BY_20
    TIP/T1A90B90, SHANKIJK=-1, 0.0022, -0.0007, ANGLE=89.9078
    MOVE/CLEARPLANE
      Does the 1mm "problem" start after the probe change?
      Or is it happening before that?
      Lately, it occurs to me
      2017 R1 (Offline programming)
        the 2x30 runs everything just fine. Once i change the probe to the 1x20 the hit points are off by 1mm.
          now i am almost positive that it has something to do with converting the probe file to the latest format. My reasoning: I added a 10mm extension to the 1x20 making it a 1x30. I selected an older version (3.7) probe file and instead of converting the probe file to the latest format, i said no. Then i tried measuring an auto-circle and IT WORKED! So does anyone think that I should delete all of my old probe files or what? so frustrating
            Sounds like you have a problem with one of them.
            Start with recreating that one and test the other ones.
              i just tried deleting the old tp20_1x20 probe file. Then i built a completely new probe file for the 1x20. I added my angles, re-calibrated them and tried to measure another auto-circle. STILL, the probe is off by 1mm. unbelievable. if only i knew what dmis was thinking....
                i have solved my problem! dont know how, but i did. I think it fixed itself once i recalibrated my other 2x30 probe in the program. sheeeeesh
                  I think you need to read this...
                  http://www.cmmquarterly.com/site/ind...=127&Itemid=82
                    Thank you James for that information. I knew most of that information already, but there are a few things in there that I didnt know. I found what i believe to be the problem. The first probe that was used to obtain my part alignment wasn't tightened all the way which probably caused the 1mm off problem when i loaded my 1x20 probe. I'll someday learn not to make such a nooob mistake.
