Auto circle question
  • Auto circle question
    Does anyone know what button will make the probe travel to the center of a hole before measuring an auto circle?
    I got all the sweet hook-ups. Know what I mean Vern.
    pc-dmis version 4.3
    ...just put a move point at the nominal location of the circle...done!
    ....well, you really shouldn't even have to do that really...just put your prehit/retract equal to the radius of the circle.....
      it there, somewhere you gotta click "center"
        ..."find hole" finds the center too...
          If you click on the FIND HOLE, and select CENTER it will probe slowly for the hole, and when it finds it, take three hits to find the center of the hole, and then do the measurement.
          sigpic What's our Vector, Victor?
            ah, he is not asking to find Center, he wants it to go in the center before and after I think it's "non center" scew it, I don't remember.
              ...move before 'n' after....set distance to zero....
                Used to be AUTO MOVE now it is AVOIDANCE move in your version (I think). Enter the amount you want to to move to above the hole, along the vector, you can make it do it either BEFORE, AFTER or BOTH.
                  The button with a small red ball in the middle of a square slit with a banana color double ended arrow on top. After you click on that button you have to insert your thing in you know what…... the way you wanted, make sure you check it before not after nor both or…….never mind…..
                    its in avoidance moves menue.
                    thanx
                    pc-dmis version 4.3
                      thanx
                      I didn't see the V4.3 in your sig.
                      Do you talk like your sig? You type like him
