Star Probe Definition
  • Star Probe Definition
    Renishaw makes a pre-built star stylus (P/N A-5000-3626) with a span of 30mm using 4 2mm balls and a fifth 2mm X 16mm stylus at 0:0 that ties the star to the probe. I cannot find a build for it in the Pcdmis probe catalog. Any help? TIA
    v2010 CAD ++ Global Image 121510
    Here what I have....I have changed the 30 to 33 due to a special tip.
      way too tiny to see!
      More than that, I will NOT say........
        Tiny is not that fine woman you have as your sig. picture 6'9"
        will work on it..
          will work on it..
          Here, try this application. No install needed, I have been running it for YEARS. Had to make it TWO zip files, one has the EXE file, the other has the HLP and LIC files. Simply un-zip them into the same directory, double-click on SNAP32.EXE. You can do screen capture, window capture, section capture, just about any kind of capture you want, then save to files from there.
            Addison,
            You meant to say 18mm right?
            What AuRules said, except for the span of 30mm select TIPSTAR2BY30 (4 times).
            Orale ese!!
            sigpicIt's corona time!
              No Roberto it is 16mm and fits into the hub of the pre-built star
                You're right...18mm is the length from the center of the star.
                Still, 2BY18MMSTAR should work for A-5000-3626.
                  Got it Roberto and thanks
