Alignment
  • Alignment
    This thing happened to me a few time, I did not know why, please advice.
    I use cad++ 3.5, after all manual alignment , twice dcc alignment, part is well locked with cad, then I start checking part, on a 5.00"wide 80.00" long corver surface, there are some specific area profile requiremnet are difference, so I have to make some local alignment (lterative) to report it, but just after this alignment, the ACTL value of the point I used to make alignment on this surface CHANGED. wHY THE ALIGNMENT change the checking value? I did not make anything fancy, normal 3-2-1 alignment.
    Thanks
    You probably said "YES" to the prompt:
    UPDATE COMMANDS WITH NEW PART ALIGNMENT?
    sigpicIt's corona time!
      This is not insert another alignment before some auto feture, it ask you to update the commands or not, it is after take all hits, then make alignment to report those hits just checked, somehow the point used to make alignment the ACTL value changed, all other points keep the same, I cannot tell why.
        Post the Code (Do you Recall any alignment in the program ???)or is just the 3,2,1 alignment
        Always Looking at the Big Picture :D:D:D
        3.7 MR1 CAD++
        4.3 Mr1 CAD++
        B&S (Global 07-10-07) -PH10T/TP20
        B&S (Microxcelpfx) -PH10MQ/TP20
          when make this alignment it is auto recall the previous alignment which is all hits took under that alignment. this alignment just 3-2-1 alignment.
            how do you know that they changed?
              Try saving the alignment then recall...
                Because the report did not make sense, so I go back have a look, I saw those touched points which I used to make alignment changed, those points did not use to make alignment no change.
                  Post code or you probably won't get any help. Your question is way too generic for analysis.
                  Bill Jarrells
                    I am keeping that for future use.... thanks for letting me steal it.
                      first take point
                      MDS_34 =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                      THEO/1242.4907,-101.231,108.8632,0.0087001,-0.6634071,-0.748208
                      ACTL/1242.4948,-101.2633,108.8604,0.009103,-0.6616598,-0.7497489
                      TARG/1242.4907,-101.231,108.8632,0.0087001,-0.6634071,-0.748208
                      THEO_THICKNESS = 0, RECT, SNAP = YES ,$
                      AUTO MOVE = YES, DISTANCE = 0.25, RMEAS = None ,$
                      INIT = 0, PERM = 0, SPACER = 0.05
                      MDS_35 =AUTO/SURFACE POINT, SHOWALLPARAMS=NO
                      THEO/1241.4245,-100.7347,108.4152,0.0085999,-0.6557929,-0.7548918
                      ACTL/1241.4248,-100.7587,108.3875,0.0085999,-0.6557929,-0.7548918
                      TARG/1241.4245,-100.7347,108.4152,0.0085999,-0.6557929,-0.7548918
                      MOVE/POINT,1241.183,-101.221,108.0178
                      MOVE/POINT,1242.0223,-100.1544,106.7727
                      MDS_36 =AUTO/SURFACE POINT, SHOWALLPARAMS=NO
                      THEO/1243.7907,-100.0478,107.8684,0.0146998,-0.6384909,-0.769489
                      ACTL/1243.7912,-100.0679,107.8442,0.0146998,-0.6384909,-0.769489
                      TARG/1243.7907,-100.0478,107.8684,0.0146998,-0.6384909,-0.769489
                      MDS_37 =AUTO/SURFACE POINT, SHOWALLPARAMS=NO
                      THEO/1242.9106,-100.1324,107.923,0.0129993,-0.6415652,-0.7669584
                      ACTL/1242.911,-100.154,107.8972,0.0129993,-0.6415652,-0.7669584
                      TARG/1242.9106,-100.1324,107.923,0.0129993,-0.6415652,-0.7669584
                      MDS_38 =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                      THEO/1243.2101,-99.5832,107.4757,0.0152005,-0.6305198,-0.7760243
                      ACTL/1243.2161,-99.6137,107.4768,0.0156425,-0.6287102,-0.7774823
                      TARG/1243.2101,-99.5832,107.4757,0.0152005,-0.6305198,-0.7760243
                      then alignment
                      DS_M| =ALIGNMENT/START,RECALL:|ABC|, LIST= YES
                      ALIGNMENT/BF3D,LEASTSQR,ROTANDTRANS,-0.0154,0.1805,0.3672,-0.0304,-0.238,0.0363
                      SHOWALLINPUTS=YES,SHOWALLPARAMS=NO
                      ID = MDS_89
                      ID = MDS_91
                      ID = SET_6
                      ID = SET_1
                      ID = MIDC
                      ID = MDS_34
                      ID = MDS_38
                      ID =
                      ALIGNMENT/ITERATE
                      PNT TARGET RAD = 0.1, START LABEL = , FIXTURE TOL = 0, ERROR LABEL =
                      MEAS ALL FEAT = NO ,LEVEL AXIS=ZAXIS ,ROTATE AXIS=YAXIS ,ORIGIN AXIS=XAXIS
                      LEVEL = MDS_91,MDS_89,MDS_38,MDS_34,,
                      ROTATE = SET_6,SET_1,,
                      ORIGIN = MIDC,,
                      ALIGNMENT/END
                      then report
                      COMMENT/REPT,PROFILE .0200|A|B|C| (ITEM 117)
                      RECALL/ALIGNMENT,INTERNAL,|MDS_M|
                      DIM LOC194= LOCATION OF POINT MDS_34 UNITS=IN ,$
                      GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH
                      AX NOMINAL MEAS +TOL -TOL DEV OUTTOL
                      T 0.0000 -0.0115 0.0100 0.0100 -0.0115 0.0015 <--------
                      END OF DIMENSION LOC194
                      DIM LOC195= LOCATION OF POINT MDS_35 UNITS=IN ,$
                      T 0.0000 0.0030 0.0100 0.0100 0.0030 0.0000 -----#---
                      END OF DIMENSION LOC195
                      DIM LOC196= LOCATION OF POINT MDS_36 UNITS=IN ,$
                      T 0.0000 0.0014 0.0100 0.0100 0.0014 0.0000 -----#---
                      END OF DIMENSION LOC196
                      DIM LOC197= LOCATION OF POINT MDS_37 UNITS=IN ,$
                      T 0.0000 0.0028 0.0100 0.0100 0.0028 0.0000 -----#---
                      END OF DIMENSION LOC197
                      DIM LOC198= LOCATION OF POINT MDS_38 UNITS=IN ,$
                      T 0.0000 -0.0102 0.0100 0.0100 -0.0102 0.0002 <--------
                      END OF DIMENSION LOC198
                      DIM LOC199= LOCATION OF POINT MDS_39 UNITS=IN ,$
                      T 0.0000 0.0056 0.0100 0.0100 0.0056 0.0000 -------#-
                      END OF DIMENSION LOC199
                      you can see the mds 34 to mds 35 almost .015" difference, but they are very close on surface ( 1.00" apart), no mismatch on surface, if you go back to look those hits z value mds35 to 37is about .015 off nominal but mds34 and 38 are almost nominal , I re-touch these two points, it shown same as all other three points, but after the alignment it go back to shown as above.
                      hope this make the question clear.
                      thanks
                        Not my particular area of expertise but it looks like something is missing. The ONLY values you show inspected OR reported are MDS34 thru MDS39 (actually the actual value for MDS34 is missing from the code so you only have ONE point in the alignment listed in the measurement section). Your alignment uses the following:
                        ID = MDS_89
                        ID = MDS_91
                        ID = SET_6
                        ID = SET_1
                        ID = MIDC
                        ID = MDS_34
                        ID = MDS_38
                        ID =
                        Your alignment is going to be based on the points selected and the ones you are asking about are a small percentage of those (only one point out of ?? How many points are in the sets?? - see what I am saying?). Is it possible your alignment is rotating and translating to the point that these numbers reflect exactly what you asked for? I think you are still going to need more code here for analysis including the mesurement actuals of the points used to create the alignment.
                        Anybody else see anything here?
                        Bill Jarrells
