I've been asked to do a mini gage r&r. The gage is not a cmm fixture, just a plain gage with nets and spring loaded tapered pins.
I have math data for the part, but not for the gage. So...I need to set up off the gage but need to use the part features to do so in order to check the features in car position.
To set up the plane, I'm taking 4 points on the net surfaces on the gage which is .8mm (stock thickness) lower than part (of course). Taking 4 surface points, do I use the THEORETICAL or ACTUAL thickness? Whats the diff?
TIA!
TIA!
