Installed upgrade into a different folder (just in case) and ran fine. But I lost my probe changer ability. Anyone know why the module doesn't carry over to the upgrade?
Hmm...problem upgrading from 3.7MR2 to 3.7MR3
RULE #1: Before installing a NEW version of Pcdmis, make a copy of the current, working directory of Pcdmis, then install the new version into the 'copy' directory.
RULE #2: Name the directory to match the version (PCD-V35MR3, PCD-V37MR3, etc.) before you install the new version into it.
This will keep all the settings, files, etc. that you need to run Pcdmis correctly and will also permit you to esaily go back to a previous version that worked better for you.
RULE #3: Make a back-up copy of ALL programs and probe files BEFORE you open the programs in the new version.sigpic
Did those things work? Does the software "know" you have a tool changer? Several times when upgrading I have had to get a new hasp program from B&S. Go into the pcdmisw folder and execute the custprog.exe it will tell you all of the currently installed modules on your machine. If the tool changer is missing just call the customer service line and they can usually have a lock program to you in a few hrs. Be sure to have all your info or be at your machine. You will need the portlock # machine s/n and the current portlock version number from the custprog screen.Badges..... We don't need no stinkin badges.
After installing MR3 into the folder and making backup copies of everything. I run MR3 and try out a program. It only runs in the graphics window. The CMM does not run. What's going on? I know this happens when you have two programs up at the same time, but I only had one and it happened only after the upgrade.I used to be high on life but I built up a tolerance.
by JoBLOCKI tried searching, no luck. Can some one provide me a link to the instructions what I files I need to copy from 4.2 to 2009?
I remember:...-
03-09-2010, 02:16 PM -
by hammerwhat file or files do I need to copy to get other users profile set the same WE are in the process of setting up new users
08-03-2006, 11:41 AM -
by mattfurtawUpdated to PC DMIS 2011 MR1 and now our tool changer is greyed out on the selection pull down. I did export all settings prior to installing and imported...
02-27-2012, 08:33 AM -
by bvn63Hello,
My colleague has a problem adjusting the parameters in Probe Changer after the changing is done (ex: 498.197 to 490) it worked but...-
09-28-2018, 02:30 PM -
by walterwWe have recently upgraded to Pc-Dmis ver.3.7mr3.
For some reason my Y axis is loinger -
I have a fixture with two alignment bushing spaced...-
10-13-2006, 01:00 PM -
