with Pc-dmis 1 yr. (actually, in college, I was an art major, go figure) Any way
it has seemed at times very logical that if I measure a feature carefully, and my finding is in tolerance, that chances are that my measurement is reliable. When checking lots of 30 and above (qty) I generally record the first measurement if it's "in" and recheck several times if it's "out". This seems like nursing the data to some extent, but if you figure that there are generally a few good numbers and an infinite number of bad ones in each case, the mathematical odds at least of hitting a good number for a bad measurement favor this approach. In our receipt inspection dept. we do this all the time, in fact we'll often use a simple positional check to verify a true pos. reqmt. God knows this isn't correct but we often will play the numbers to get through the workload.
I secretly sneak around to check things correctly only to be singled out as "dragging out the process". What kinds of meatball processes have y'all
had to put up with? Do any of you use super glue to stabilize your set-ups?
(never on a surface plate I hope)
Tks for reading-
Mike
