I've just upgraded to V3.7 MR3 from MR2 but didn't overwrite the old files. I'm just wondering where my personal settings are kept regarding button layout, font colours etc... I know it's in a file somewhere...operative word being somewhere!!
Settings and Layouts
I've just upgraded to V3.7 MR3 from MR2 but didn't overwrite the old files. I'm just wondering where my personal settings are kept regarding button layout, font colours etc... I know it's in a file somewhere...operative word being somewhere!!Tags: None
look in the "old" mr2 folder for a folder titled in your login name
copy/past the entire folder into the new mr3 directory
make sure to check your "search paths" for proper direction to the appropriate folders for your probes and suchsigpiccall me "Plum Crazy"....but you only go around once!
Originally posted by Mike N.look in the "old" mr2 folder for a folder titled in your login name
make sure to check your "search paths" for proper direction to the appropriate folders for your probes and suchXcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Probe head visible in simulation
I've another question on this, maybe....
I'm writing offline and on this particular prg I cannot get rid of the Probe Head. I've always seen the probe when it simulates but the whole probe head is in on this one and I cannot get rid of it. If I rotate my part a little it lets me see where the hits are going to be but I do want to do that for feature an this part.
TIA
DuaneXcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Originally posted by GoodluckOpen up the probe window (ctrl+alt+p). Down at the bottom where the probe is built up double click on the portion of the assembly just above the tip. Uncheck "draw this component" and click ok. Everything above the tip will not be drawn.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
So when you open the probe window they are unchecked or have they reverted to being checked?
Try checking them all, clicking ok in that window, click ok in the probe window, re-open the probe window and unchecking the ones you don't want, clicking ok in that window, then clicking ok in the probe window.
Stab in the dark!
Well I found the problem.... I have 4 CMMs on the floor and had the probe file loaded for another machine. I went in and did as you had said and realized that the wrong file was loaded. Thank you for the help.
Contura Calypso 5.4
by vajncI would really like to know if there is possibility of importing the toolbar-personal settings which I have created in PC-DMIS 3.7, from one computer...
11-16-2009, 09:13 AM -
by RussLIs there any way to standardize settings for every user regardless of login without setting them in each login?
08-16-2006, 01:53 PM -
by TKOFaithI just upgraded from 2013 to 2013 MR1. All of my toolbars are screwed up now. Is there a file I can copy and paste from 2013 that will restore my toolbar...
01-06-2014, 01:47 PM -
by nicolaegI got my CMM on a network(pcdmis v4.4).
When I log in now with my network username I have totally different menus, settings. I am able to do changes...-
03-10-2010, 08:27 PM -
by markyI want to reinstall PC-DMIS v4.2 MR1. Can I reinstall over the old copy of PC-DMIS or do I need to uninstall it first? Which files do I need to save from...
05-03-2011, 09:05 AM -
