Deleting .CAD files
  • Deleting .CAD files
    When I create a program in PCD a .CAD file is generated.
    When I delete that program PCD does not delete the .CAD file.
    Is there some setting I can change?
    If not, why not?
    Why would the folks at Wilcox set up a situation where your local hard drive is filled with usless .CAD files.
    I go into Windows explorer every few months and clean this stuff out.
    It's a pain.
    Lately, it occurs to me
    2017 R1 (Offline programming)
    With all programs closed, go to file>operations>delete. That will delete both your .cad and .prg file after you make a choice.
      But you are supposed to open one any program to use
      File>operation>delete. I am away from computer right now so I can not imagine at this time.
        You can do the file | operations | delete with a program open as well.
        I'm assuming in the original question John is referring to using the file | open dialogue box to delete files since by default it only shows *.PRG files. There is a drop down for files to show that includes *.PRG, *.CAD to show the both files for each program, then both can be deleted manually.
        The other option is to use File Explorer from windows.
        PC-DMIS 2016.0 SP8
        Jeff
          I just got into the habit of deleting the *.prg, *.cad using a shortcut on my desktop that points to the WAI/Pcdvxxx/Programs.
          sigpicIt's corona time!
            James, with all program closed.
            File>operation>delete. Is it going to show me the list of files from which I will select one I want to delete because I don't want to delete anything which is important and has to be subsist in PCDMIS folder. I normally don't try this function. I typically use delete switch in keyboard.
              It opens your program directory and you select what program you want to delete.
                Thanks you very much.
                • cmm-measurer
                  CAD by association
                  by cmm-measurer
                  I have a general question regarding the the use of CAD files in PC-DMIS. I was working a couple of years back with a contracted programmer from Hexagon,...
                  04-28-2009, 10:24 AM
                • T Miller
                  deleted file..
                  by T Miller
                  I had a few files in the trash bin.. I went to restore them and hit delete
                  anyway to get these back.. Not a real biggie just have to reshoot the...
                  04-10-2006, 02:01 PM
                • milul
                  using a .cad file
                  by milul
                  To be more specific about my previous post, checkig a part that ; If you are checking a part that has been checked before, you open up the prg file...
                  01-29-2007, 04:45 PM
                • billygwh3
                  Renaming files....
                  by billygwh3
                  When I make a change to a .prg file name do I need to change the other .prg file names (prg.~ and the prg.(carrot symbol) associated with that particular...
                  03-30-2015, 03:08 PM
                • Ken8282
                  Step files
                  by Ken8282
                  I just opened a program I had written a week ago. The Step file I used I had to import again. Is this because I moved the program file to a Seperate folder...
                  10-08-2012, 05:34 PM
