Greetings,
I use ver. 3.7mr3 I have several one inch angled drive pins protruding from the back of a plastic injection mold. I am set up on the back of the tool.(PLN1) I take three hits out near the end of the pin (away from the back) and three hits near the back. I create a cylinder. I select the angle output, select CYL1 and PLN1, 2D angle, to feature, I do not get the correct angle. It should be about 12 degrees and I get 4.5 degrees. I have tried different ways of doing this and it just will not come out right. Any and all ideas or suggestions are welcome!
Thank You,
JCTB
Thank You,
JCTB
