Hope this isn't a stupid question but...
How fast do you folks run your machine? I know certain machines can move faster then others so if you had to group them all together, would it be at 1/2 speed (50%), wide-open (100%) or somewhere in-between?
Also is machine accuracy influenced by rapid movement or is that influenced by the touch speed/trigger sensitivity only?
The reason I ask is we have one programmer here that creamed a PH10 running full bore and swears that running at 1/2 speed he never had a problem. My machine I run at full bore but it's a tank the can only achieve a speed of 70mm/sec2 The others run @ 35% & 50%.
What advantages if any will be achieved if one runs slower vs. one who runs wide-open? (not the obvious of running more parts then the other either)
Thanks,
Greg
Thanks,
Greg
