I'm taking manual hits on 2 OD's after my manual alignment, because these 2 features are tie rod ends and may change position from part to part. I use these manual circles' xyz coordinates in DCC mode so the demon knows where they are. The problem I have is that when the next part is measured, and the rod ends are shorter or longer than the one I used to write the program, upon taking the first manual hit on one it gives me an error. "Measured hit taken outside tolerance zone: Distance = 10"
How, or can I, change this distance to something like 100? Or is there another fix?
4.3mr1
Thanks!
4.3mr1
Thanks!
