It should start the move and the rotation at the same time. They are not related in that the probe will move at the current move speed and the probe head will rotate at what ever speed it always rotates at. When adding a move all just make sure that there is clearance for the probe to rotate thru the entire move path. That way, it won't mater if you run the program with the move speed at 100 or 20. I used this type of movement in my DirectInspect days and cut 30 min out of a 4 hour program. It had a LOT of probe changes.
I saw a video of the new Global S and the probe is rotating during a move, similar to the 5-axis but it isn't. Is this a possible feature with a PH10M,...
So im trying to use the crazy move commando that changes angle while doing a movepoint, but whenever the head locks in the new angle the machine stops...
I made a program and finally I took move increment (0,0,85) in MM. The CMM probe had enough space to go up so I took another move increment (0,0,50)...
