Can't remember due to the rumor of 33% of our work force being cut. Where do you change the color of the printouts. I does a red=out of tol. black=in tol. I would like to add a blue to tell the operator it getting close to the limits. Everywhere I know to look about colors does not seem to be right.
Callout colors.
Originally posted by scanner View Postedit-graphics display window-edit dimension color.sigpic
Originally posted by AuRules View PostCan't remember due to the rumor of 33% of our work force being cut.sigpic
Always Looking at the Big Picture :D:D:D
3.7 MR1 CAD++
4.3 Mr1 CAD++
B&S (Global 07-10-07) -PH10T/TP20
B&S (Microxcelpfx) -PH10MQ/TP20
Originally posted by JM222 View Post...leave the color out...save your company some money...those ink cartridges get expensive...especially on long reports 20-30 pages...up to 19 cents per page...
If I did that they would never be able to figure out what I was showing them!! RED=BAD, GREEN=GOOD!!
yea i've jumped through that hoop before too...finally due to the cost..the operators had to actually look at the numbers...and they had to compare them to a print...what a concept!! Ended up saving us ~5000$/month
Originally posted by JM222 View PostIf I did that they would never be able to figure out what I was showing them!! RED=BAD, GREEN=GOOD!!
Originally posted by JM222 View PostJust found out that if you print in the text mode only the color scheme does not work.
It can be done w/ some variables (percentage of tolerance) tied to font color...it's tedious..but can be done.sigpic
I've never done it myself...a guy far more experienced than me said that you have to assign the font color as a variable for that particular section of the "dimensioning block"...using a percentage of the tolerance...Font Color Green for 0-25% of tolerance...Font Color Yellow for 25-75%...etc...I'll fool around with Excel to see if I can dig something out of it in terms of scripting....he did say that is has to be done separately for each dimension though
by jkb_mcgI know I've discussed this before on here but I couldn't find it....
Does anyone have problems in 4.2mr1 with the dimension colors staying...-
08-18-2008, 03:24 PM -
Is there any way to change the dimension type colors? I know how to change the dimension tolerance colors, but the dimension type colors....I have no...
04-05-2012, 04:29 PM -
by inspector212How do I change the color of the features in the CAD window. The points are at nominal. There is no deviation. Two are green and two are red. I have both...
06-08-2007, 01:30 PM -
by AJHVW93Is there a way to change the color of the text in the elogo.dat and logo.dat files? Its not in the edit window colors. Thanx
01-04-2008, 05:47 PM -
