Machine Parameters Question ?
  • Machine Parameters Question ?
    Reference: Edit-Preferences-CMM Interface Setup-Params-Max Speed. I'm trying to see what others are using on this setting. Mine is set at 300 XY&Z. Anyone care to share there settings on this? Thanks in advance for any and or all replies. V3.5MR1 tlnzz.
    PC-DMIS V3.5 MR1. CAD++
    Global Image 574.
    Windows XP
    ASQ-CMI. - 1986
    Journeyman machinist, August 1970.
    I think mine are at 175. I believe this is based on the type of machine. I never change it. I use movespeed to modify the program.
      I believe this setting has different settings for the different versions of the software. I can remember upgrading from V3.2063 to V3.5 and the machine moved at a crawl. I think the previous setting for V3.0263 was 175 XY&Z. It took a while to finally settle on the 300 XY&Z setting. ??? tlnzz.
      Global Image 574.
      Windows XP
      ASQ-CMI. - 1986
        This Global image with leitz controller is set to a max of 320
          Max speed
          My Global Image is set to 500 (xyz)
          Jay Gus
            Global 7 7 7 is set at 1000
              WOW!
              WTF
              warp speed Mr Soolu (sp?)
              more jigawatts Dr Brown
                I didn't say I run that fast just what it was set at when we got it.
                  machine parameter
                  If the machine parameter for move speed is set to high, and the move speed is at 100%, you will get a error message from PC-DMIS.
                  Tim
