need to add temp comp in prog
  • need to add temp comp in prog
    we have to measure hardened a-6 plate with
    (2) .50000" holes 5.00000" apart and we are finding
    that our customer is getting a .0001 difference in true position
    reading then we get this translated to + or - .000035 millioniths x and y
    we need to add temp comp. and also want to print what our part sensor
    reads on our report also.
    can anyone help
    Thanks Rich
    Is your machine even capable of those tolerances?
    To be able to check to 0.0001", your machine must be able to check 0.00001" accurately, every time, location and repeatability.
      yes accurate within 15 millioniths 800 600 600mm
      lot o money but it is accurate
      also cost lot o money to calibrate
      $10,000 a year
        $10,000 a year
        ......waiting.......
        well what is it?
          Ditto, and what types of products do you produce?
            it is a LEITZ pmm 866
            you wanted to know what kind of machine it is
            sorry i am a bit slow today upstairs
            800mm 600mm 600mm
            volumetric tolerance is .0000015
              Sweet machine.....ever crash it? I hope not
                $37,000 for a new head
                Nope "NO" crashes here ...... yea right
                fortunately it has crash detection built in so when it
                sees what it calls "probe head deflection" it can put the
                brakes on before it does any damage
                kinda like the new mercedes when it knows your gonna hit
                it will adjust you seat and seatbelts for the best "crash position"
                I am serious LOL
                  we make everything from
                  targeting parts for an f16 fighter jet
                  to dental and spline inplants
                  to robots that build hard drives for computers
                  to parts for missle defense
                    Can't you just do a "get temp" from the temp setup screen and call it into a comment output?
                      OVER THE FULL 4 ° TEMP. RANGE YOUR ONLY LOOKING AT .000096" OVER A FULL 5" PIECE.
                      IF YOUR BOTH IN OR NEAR THE MEAN TEMP. I THINK THERE IS SOMETHING ELSE GOING ON HERE.
