My print is calling out minimum of 3 control points for //. Print is dimensioned using ANSI Y14.5M-1982. I do not have a reference to this standard. Do I take 3 points, average it, then dimension to the datum plane? Or do I take the highest or lowest points?
// Question
without seeing the actual drawing and callouts......
sounds like the 3 points are your "reference plane"...you will need to level to these 3 points, then sweep the feature plane with the // callout. total indicator movement is the actual result to report....high and low doesn't matter ( it does, but for simplicity we won't look at that right now), it's the difference between the high and low
so if you indicator shows a high of .002 and a low of .001 your total // is .003
good luckWhich one gets ridden today? MPH vs MPG..tough choice, both are FUN
Starrett RGDC 4028-24 :alien:
Bob is correct, I should of stated that on a certified flat granite plate, you should put the part on say for example three .100 gage blocks If you have certified balls that would be great, certified pins will do. Zero out you indicator on top of the part and then take you high and low.sigpicSummer Time. Gotta Love it!
by GEO3DOK so I’m measuring a large part and measuring the datum [A] plane at A45B180 whilst creating my alignment. The reason for this is due to restricted...
05-08-2015, 06:04 AM -
by tnguyenHi.
I have a question of Surface origin. Let say I measure 50 points on Surface then construct Plane Datum A. I want to create Datum A origin...-
03-20-2009, 08:18 PM -
by BedancNeedless to say it is giving me a headache.
For example I have a top plane (hollow thin walled plastic parts) defined as datum A on many...-
03-15-2016, 05:09 AM -
Hello everyone...
We are currently having a discussion about leveling to a primary plane, (Datum A). The discussion concern is whether...-
01-08-2007, 09:30 AM -
by Chris MurphyFirst, I create a plane using three vector points. I try to dimension the flatness of this plane but it always says 0.000. I know that the surface isn't...
02-25-2008, 03:06 PM -
