Report Woes
  • Report Woes
    Got a problem I can't seem to fix - Runout shows on the report as a pale green, when printed you can't see it. How do I make the type color default to black, and only out of tolerance condition red? I know it's probably staring me in the face but I'm stuck. Any help is greatly appreciated.
    Originally posted by Ironhoe
    I got something under my sporran for you, take care of it and you got my vote.
    It looks like your color settings may need to be adjusted for your report template. Try the following:
    1. Load the Report template in the Report Template editor.
    2. Right-click on the TextReportObject in the template and the Properties dialog box appears with TextReportObject1 selected in its drop down list.
    3. Click on the Colors property.
    4. Select the Dimensions item in the Command Text Colors tree view.
    5. For the color of Marked text, click the Edit button and choose black. It will ask if you want to modify all the children items. Choose Yes. This should cause all Marked dimensions to appear as black text in your report.
    6. For the color of the Error text, ensure that the color is set to red.
    7. Click OK,and save your Report template.
    8. Reload the template in the Report window.
    Jared Hess - Techwriter @ WAI
      Worked great - thanks Jared!
        I had the same problems with the report screen. Thanks Jared, your solution worked great!!!
          What happened to the attachment?
