Is there a way to create a fixed radius circle or arc from two surfaces with a gap in between? I have to create the centerline for a part from 2 radiused wings with a large gap between them. TIA 3.5mr2
Fixed radius arc in interrupted surface?
by Ines_MI’m looking to using fixed radius option when measuring an arc in two cases, because I cannot achieve repeatability otherwise.
First,...-
06-17-2018, 07:48 AM -
by Glenn DowneyI'm measuring a part with a very short arc length. The part is about 30" long with a diameter call out of 224". Instead of using vector points...
11-08-2015, 07:05 PM -
by Onehot82I am new to pcdmis and tried searching for this but didnt come up with the right info. I am trying to measure a partial radius using polar radius and...
02-21-2012, 07:12 AM -
by DAN_MI've got a small ring shaped part with a spherical radius on the inside. Am just wondering how you all would handle this part. I have the part on double...
09-26-2017, 04:12 PM -
by mdobb829Without "Opposing Elements" you don't get a feature of size, so is there a way to accurately measure a segment of a circle in 2014.1? See the...
01-11-2016, 02:24 PM -
