Hi all I purchased a custom disc probe with a txt. Probe file. I converted the the .txt to .DAT file and moved it to the PC DMIS 2017R folder under program...
I have a number of older programs that haven't been run in a while. Most of them use older probe definitions that are no longer being used. Whenever...
Has anyone else had this happen? I created a new program this morning and selected the probe file that I wanted to use. I went into the probe qualification...
When building a new probe file to replace the current probe file (current file is corrupt or otherwise because it won't calibrate at any other wrist angle...
