not on tip list
  • not on tip list
    I have a tip A-5000-7812 renishaw that I cannot find on my tip list. What do I do now? is there some where I can get it or how do I create it?
    You have to use the "userprobe.dat" file and add it there.
    David Monroe
    Is there any way to stop the infernal beeping!?
    3.5 MR2
    Dual Arm Vento
      Captain, what exactly is the probe. I can write the text for you and then you can add it to your probe.dat file.
      sigpic GDTPS - 0584
        It is a renishaw a-5000-7812 2mm cylinder x 20 mm. the problem is I can't even find my probe.dat file anywhere
          It is on your hard disc drive in the 'PCDMIS folder', where everything runs from located alphabetically in the P's. You need to 'open it with' & choose notepad or wordpad. You can then 'manipulate' the contents as below. I too have a couple of probes to put in & copy pasted this little lot in readyness. Just short of a Roundtuit @ the present.
          Here is some tip data from the probe.dat file
          Originally Posted by craiger_ny
          ITEM:TIP5BY10MM M2
          begintip
          ribcount 10
          color 142 142 142
          cylinder 0 0 0 0 0 -3 3
          cone 0 0 -3 3 0 0 -7 2.5
          cylinder 0 0 -7 0 0 -10 2.5
          color 255 0 0
          sphere 0 0 -10 5
          hotspot 0 0 -10 0 0 1 5 5 ball
          endtip
          Change the Sphere to -102.5 instead of -10
          Change the HOTSPOT to the same.
          This will put the 'ball' of the tip at the correct distance from the threads. You will also want to change the 'name' of the tip, change tip5x10mm to waytoo****long so that it will showup as a unique tip in the list.
          The cylinder can be changed from -10 to -100 with the diameter (2.5) changed to match the diameter of the probe. LEave the -7, that is where it starts from, the -10 is where it goes to. Basically, you are building the probe "DOWN" from the threads (where it connects).
          Poleaxe
          Beware the environment you live in for it will shape you
          Be careful the friends you choose for you will become like them.
            It's in there. It's called a shank probe not a cylinder probe.
            ITEM:TIP2BY20MMSHNK M2
            begintip
            ribcount 10
            color 142 142 142
            cone 0 0 -3 3 0 0 -7 1.5
            cylinder 0 0 -7 0 0 -12.5 1.5
            color 255 0 0
            cylinder 0 0 -12.5 0 0 -20 2
            sphere 0 0 -20 2
            hotspot 0 0 -20 0 0 1 2 7.5 shank
            endtip
            sigpic GDTPS - 0584
              Thanks Guys I got it!!!!
