Depth question
  • Depth question
    Happy pre thanksgiving all.
    I'm taking a boatload of points in an ID. I've got them programmed to go down to 12.0mm and take all the points at that level. once it's done running i see my actuals and they are all over the place. meaning i have about a .010 difference in some of them. how can i remedy this?
    thansk
    " Why don't you jump off a bridge in front of a train?"
    You don't have a value entered in the pitch box for an autocircle do you?
      Are you using cad
      THANKS (CAD IS ALWAYS MASTER)
        i'm checking separate points in a dia. not a ID so no pitch available to me.
        Are you using cad
        yessiree
          f5, Uncheck FIND NOMIALS DURING EXECUTION if checked
            yessiree
            I'm not sure how CAD plays into this, I don't do CAD.
            Check your hit vectors to ensure that the k component is zero for all.
            If they were a non-zero value, with a perfectly round hole at nominal position, all the hits would be at the same level, but due to variation in those, the hits could fall at different levels.
              Next idea;
              Are you dimensioning in the same alignment in which you measured? A change in the feature used to level or rotate for alignment could cause this.
                wasn't checked.
                  thansk
                  A .01mm is not that much. It may be that is what they are. I misread and thought it said Nomials. You are only talking about 0.00039 inches
                    ok...so i'm checking this in the X axis. so i would my I vector should be at 0 (which it is).
                    also i'm dimensioning using the same alignment as i am when i'm checking the features. i really don't think it's an issue, but when export the cad data, the engineer is seeing the points on different levels of X. and we need them at one level to make our mold adjustment.
                    make sense? either way...it's $%)^&*&()
                      I missed mm. I thought it was .010 inch!
                      .01 mm is nothing to worry about. That's probably just due to the machine's ability to move only so 'fine'.
                        So the hole is aligned with the x axis (using A90B-90 or A90B90)? In that case, the I value should be zero.
                        I think there is a way to eliminate the reporting of the error in that axis. Matt's the guy to ask about that. I seem to remember him posting on that sometime.
                          Snap point
                          Try taking these hits with "Snap Point" turned on.
                          Global Advantage 12-15-10 PH10MQ SP600M V4.2MR3 CAD++
                            SNAP! That's what I remember Matt talking about!
                              Vector points & snap on 'projects' the points taken BACK to the nominal vector line, eliminating the 'drift' any and all machines have. For example, if you are taking a point with a vector of 0,0,1 (up and down in Z), at X10, Y20, Z0, your machine might hit at X10.010, Y19.990, Z0.125. Using snap, it will report the point as being taken at X10, Y20 and Z0.125, it 'snaps' the point back onto the perfect vector line from the nominal location and you then ONLY get the vector deviation.
                              • j.gonzalez
                                pitch dia
                                by j.gonzalez
                                trying to check pitch dia runout of an id thread to an id datum bore can not get a good reading what is the best way to check this and what style probe...
                                04-21-2009, 04:47 PM
                              • Vertman
                                Measuring Threaded holes CAD issues.
                                by Vertman
                                Never used this in PCDMIS, but seeing as our latest project has a touch of the comedy tolerancing about it, i thought i ought to give it a whirl.
                                07-17-2008, 04:58 AM
                              • rem1187auto
                                pitch dia.
                                by rem1187auto
                                does anyone know how to check the pitch dia. on an o.d. 2 3/8-5 api tapered thread?
                                03-18-2011, 11:02 AM
                              • Liambo734
                                Scrolling Threads
                                by Liambo734
                                Hi Folks - When using the autofeatures circle option to measure threaded holes I wanted to know If once you enter the thread pitch you have to set the...
                                12-09-2008, 12:47 PM
                              • AuRules
                                Pitch
                                by AuRules
                                Never used the pitch box in a threaded hole, always used center finders but I'm going to try it today.
                                My question is when I enter pitch...
                                06-29-2011, 07:48 AM
