Does anyone key in .5 to get a vector of 45 degrees? I have done this since my days of CNC programming. PC-DMIS recognizes this as 45 degrees and writes .7071068 into the code for me.
When vector .5 = .7071068
Originally posted by rickfngp View PostDoes anyone key in .5 to get a vector of 45 degrees? I have done this since my days of CNC programming. PC-DMIS recognizes this as 45 degrees and writes .7071068 into the code for me.
it gives all the vectors needed.sigpicRichie the Villian!!
V4.2 MR1 CAD++/MISTRAL 10-07-07 DCC/XP
How do you key in .5, where and in what to get it to come to .7071068
I have always typed in the right vector approach values to get what I wanted.
Never tried anything else.sigpichttp://npmichaels.com/ (My sons book)
THANKS (CAD IS ALWAYS MASTER)
Originally posted by pniven View PostHow do you key in .5, where and in what to get it to come to .7071068
Never tried anything else.sigpicDigital 3D photography :cool:
PC-DMIS CAD++ v2014 SP1 -- Windows 7 -- Mitutoyo Bright 707 :rolleyes: PC-DMIS Vision 2014.1 -- Optiv Performance 664
Originally posted by rickfngp View PostAuto Vector Point is where I usually use it. Since 45 degrees is half way between 0 degrees (vector 0) and 90 degrees (vector 1), then .5 is half way between 0 and 1. Since my CNC programming days it's been a habbit. The instructor in PC-DMIS programming class had never heard of it either.sigpic
I will have to try that.sigpichttp://npmichaels.com/ (My sons book)
Originally posted by Matthew D. Hoedeman View PostWhat is happening (I am guessing) is that you are putting that 0.5 in for TWO of the axis vector in the window. Pcdmis 'sees' 2 vectors with a value, one without, and then finds the closest "2-D" vector to match what you have put in that is correct for the math, if you follow, since Pcdmis will NOT allow you to have a vector that does NOT add up to the correct SQRT(I^2+J^2+K^2) value of one. Put in 0.6 and 0.3 in the IJK somewhere, create the point (no need to measure it) and it will give you the closest 'true' vector values to match the garbage you typed in.sigpicDigital 3D photography :cool:
Originally posted by rickfngp View PostYou are correct Matt, except for the reference to garbage. It's a convenient shortcut.sigpic
where do you put '0.5' to get a vector of 0.707 in 'Auto-vector point' ?
i think i must misunderstand what your saying.sigpicRichie the Villian!!
Originally posted by Matthew D. Hoedeman View PostIn the IJK holes in the AUTO FEATURE ~ VECTOR window, you can put ANY identical absolute value amounts (in TWO of the vector and a zero in the third, where it say IJK) and when you create the point, Pcdmis will 'correct' the vector to be proper math. So, you could use 0.1 and 0.1 and 0 for the 3 vectors and it will give you the proper vectors for the 45 degree. You could also use 1, 1, 0 for the vectors and you will STILL get a 0.7071068 shown for the vectors in the edit window
thankyou.sigpicRichie the Villian!!
OK, I follow you. I have been wondering about that formula SQRT(I^2+J^2+K^2). If it works when the probe travels at a 45 degree angle on both the X and Y axis but does not move on the Z axis, then how can it work if you then program the Z axis to also move at 45 degrees?sigpicDigital 3D photography :cool:
Originally posted by rickfngp View PostOK, I follow you. I have been wondering about that formula SQRT(I^2+J^2+K^2). If it works when the probe travels at a 45 degree angle on both the X and Y axis but does not move on the Z axis, then how can it work if you then program the Z axis to also move at 45 degrees?sigpic
by NMC_CMMI'm not sure if my main question really asks what I need to know.
So here's my situation. I have a part that we're EDM'ing out some fan-blade...-
06-21-2010, 07:38 AM -
by JigneshWe don't need to select values of Report vector and update vector for vector point in sheet metal piece. An enginner from our software company told me...
04-19-2016, 03:09 PM -
by Big JohnPlease, who can help me??
Now , all of a sudden, engineers and managerswant to know the exact meaning of the T on the measuring report....
02-27-2007, 06:31 AM -
by JigneshI have never turned on sheet metal in F5 key for the work piece which is made from sheet metal material. We have only one part made from sheet metal...
02-09-2016, 01:39 PM -
