I just found out that I had a maintenance agreement for calibrations and repairs to the machine. I have a Global Image 9-12-8. What type of calibration do you guys mainly use (b89 or something else) and as far as the maintained goes what should I be concerned about. They gave us a price; now that we paid it they want to charge us $900 more. I am wandering what are some of the concerns I should have? I went back to some older posts but still not sure what to ask about. Any info is appreciated. This is not the SMA, just a maintenance agreement.
maintenance agreement not SMA
My 1st question is why they want to charge you more money for. As far as calibration goes we usually have the ball bar calibration. I did have my 7107 laser calibrated once.sigpic.....Its called golf because all the other 4 letter words were taken
My 1st question is why they want to charge you more money for. As far as calibration goes we usually have the ball bar calibration. I did have my 7107 laser calibrated once.PCDmis 3.5mr2 CAD++
We do not have a maintence agreement. If it was me i would not pay anymore money. If you can get the ball bar calibration at that cost then that is what i would do.sigpic.....Its called golf because all the other 4 letter words were taken
No the 10360 is a different spec. B&S manufactures the machines to the 10360 at their facility. When the machines are installed they get calibrated to the b89. the B89 has a volumetric requirement ahd the 10360 has a linear auccracy requirement ( generic explanation ). The specs are different for each machine make and size. I believe the maintainance agreement covers filters and light PM. If anything else was done to the machine then it would be billed I assume....?!?Badges..... We don't need no stinkin badges.
My understanding is there is a SMA for software
ie tech support for programming software issues as well as update to software when they are released
an SMA for machine itself but this covers working components of machine
BUT NOT the renishaw (probing) components
it may be all part of how details are contracted with sale of machine also
Dale,
You should at the very least expect linears for each axis, repeatability, and volumetric(ball bar). I think B&S tries to pass the Linear Ball Bar off as a "accuracy" check but I have my questions about that. You should see a webber bar or equivalent (that would include a laser or kobe bar) used on your cmm. If not, question how they know the machine is accurate. All of this has nothing to do with ISO it is just common sense calibration stuff. Using the Linear Ball Bar is sort of like checking a 0 to 1 mic only at 1 inch and not at the various increments along the way.
You probably don't need "befores" since you are your own customer. The "befores" will pretty close to double the cal cost.
Yeah the b89 checks all the necessary criteria for a valid calibration. I stated that the 2 word explanation was generic. The b89 uses a ball bar and checks several angles at several heights. This insures linear accuracy and squareness across the cube. As for accuracy the b89 has a larger margin for error than the 10360. This is relative also. I have a 998 image with a b89 of .008 mm, if I remember correctly, (across the entire cube) and a 10360 of .0017mm+ (L/333) L=length of standard.
There is a lot more to the discussion than can be covered here in a few lines of text. My suggestion is to read up on both the b89 and the ISO10360 and decide for yourself what your shop might need. IF your shop is like 99% of the shops in the US then the b89 should be enough of a cal to make the parts you supply. If the 10360 is the spec that you need then you would probably already know that and have several things in place to insure that your machine can meet the spec and several procedures in place to guarantee that your part measurement is that accurate.Badges..... We don't need no stinkin badges.
Originally posted by Sean HarrisAs for accuracy the b89 has a larger margin for error than the 10360.
The b89 covers the entire cube with 1 number. The operator has absolutely no idea where that error is. The entire error could be in the -z- axis above the table by 10" in the far back left corner. The ENTIRE cube is covered with one number. Granted it would be highly unlikely for all the error to be within a 2-3" section of the cube. My point was that the b89 has an "error number" assigned to it and we have no idea where that error is. The bigger the cube the larger the tolerance for error in the b89. The 10360 is set up for accuracy over a specified distance, so that no matter what you are measuring you always know what the accuracy of the measurement is.
The advertised b89 accuracy for my 7 7 7 global image is .009 mm. Now it is possible for ALL that error to be in 1 general area.
The same machine has an ISO10360 of .0017mm+(L/333) that means that no matter where on the cube you are you know what the errors are.Badges..... We don't need no stinkin badges.
by TRD_racingHi All,
I need some advice. Just found out that I had a maintenance agreement for calibrations and not sure what else. We do not need to be certified;...-
06-23-2006, 01:38 PM -
You didn't know this? Yeah, that's one of their most amazing scams ever.
Instead, let it lapse for 8 years then just buy it again, it's...-
10-01-2010, 01:34 PM -
by mdobb829In June of 2007 we purchased a new Brown & Sharpe Global 12.15.10 machine. As part of the deal we had Hexagon upgrade our LK CMM to PC-DMIS. Now...Yes75.00%36No25.00%12
06-10-2008, 09:20 AM -
by giantslayerThe company I am now working for does not have a service contract with Hexagon and has been having RMS a third party company come in and do the calibration....
07-30-2015, 06:01 PM -
by A DishoOur company is located in GTA Ontario-Canada ,we use pc-dmis with Brown & Sharpe. and every time it come to calibration& renew Maintennce agreement...
09-14-2009, 11:28 AM -
