what's up with the different color file names in the PC-DMIS folders? They are blue instead of black, what is the significance of these particular files and why the different color than the rest? We are using 3.7 MR2 on two HP PC,s. I don't believe the CMM type is relevant. Is this a windows or PCDMIS thing?
Different color file names in PC-DMIS folder
From "Defining Edit Window Colors" topic in the Help File:
The Edit Windows Colors dialog box allows you to define the colors used for the Edit window text and background when you have the Edit window in Command modes. You can also export your color scheme to use on different computer systems or import external color schemes.Jared Hess - Techwriter @ WAI
Right click your desktop and bring up the desktop settings screen. There you will see the windows scheme menu. I believe there is where you can change the colors of your windows/text/etc. Hope this helps.I used to be high on life but I built up a tolerance.
by John KuglerMight be a dumb question, but I've seen tetrahedrons a different color than the standard red and green. Is there a way to change it? Geez I remember...
02-21-2008, 03:13 PM -
by RavenmaniacGood morning ladies and gentlemen. We just converted some of our CMMS from 4.3 to 2012 and are running into a bunch of glitches. Can anyone explain why...
12-12-2012, 08:21 AM -
by 2MMSTARSo as luck would have it management decided that my pc was too slow and if they upgraded it would make me a much more efficient and faster programmer....
09-05-2013, 09:01 PM -
by AJHVW93Is there a way to change the color of the text in the elogo.dat and logo.dat files? Its not in the edit window colors. Thanx
01-04-2008, 05:47 PM -
by NinjaBadgerWant to make your report comments stand out a bit more?
By preceding the comment text with
~~1
~~2
~~3...-
09-17-2015, 06:07 AM -
