Could you give me any information on how to use the star probe that I have? We did not go over this at all in my cmm class. The star probe I have 4 legs, each with a 2mm ruby. From the center hub (which is around 5.5 mm dia.) to the center if ruby is around 15mm. Across from end to end is of course 30mm. I think I can build a tip using this and the parts in the box. I don’t know how to describe it. All I have in description of the tip is 2X18MMSTAR and also a 10BY6.5STAR. I’m assuming that I can use the 2x18 with 18 being distance from ruby center to back part of star hub (with the 4.5mm long connector thru star hub).??
All I found for each or the 4 “arms” were TIP2BY10MM which doesn’t look exact as far as the length goes.
How can I set this up, as far as making all the physical connections and descriptions? Also, how do I calibrate it? How do you know where to position the star so that it will come out along the X and Y axis when put on the machine?
Sorry for all these questions at one time. I know nothing on this.
Thanks.
Thanks.
