Unigraphics,ProE,ACAD plugins?
  • Unigraphics,ProE,ACAD plugins?
    Anyone here use one of the CAD interfaces? I am running 3.7MR2 CAD++
    But all the engineers are either running UG, or will be switching to it. Will I (or we) benefit from me getting the UGDCI? Anyone?
    Bueller?.............Bueller?..................... ...Bueller?.......................Anyone?.........
    CMM Programmer
    Jackson Michigan
    Mistral 7.7.5
    4.3MR2
    if you get a DCI...PCDMIS will be looking for the actual seat of the CAD in order to open the CAD file, PCDMIS itself will not open the file. this way there is NO TRANSLATION of the CAD file at all.
    if you get DCT...PCDMIS will just import the cad file and read it as translated, not always 100%, but probably close enough in most cases
    so, if your CAD seat is not "available" across your network to your CMM
    9PCDMIS) pc, you will be SOL
    I am not sure if anyone else can use the CAD program while PCDMIS is using it....probably not, which means needing another "seat" in order for the engineer to still do his job while you do yours (verify this with Hexagon)
    Starrett RGDC 4028-24 :alien:
      I am running PC-DMIS, v3.7mr3. I also use Unigraphics NX20. When I import a Unigraphics-.prt file into a PC-DMIS program it basically "borrows" a copy from the cad system. The engineer will still have full control of the original model at the same time. As a matter of fact if the engineer changes the cad model from the time you first imported the model into your program, and the next time you open the CMM program, PC-DMIS will ask you if you want use the changed model or a copy of the the original cad.
      Ron
        Oopps,
        if you want to use the changed model or a copy of the the original cad.
        Ron
        • Kstein1
          CAD model lost
          by Kstein1
          Has anyone had a problem with opening a program that you've used before and the CAD is gone? It still runs the program. I can import the CAD again and...
          03-15-2016, 08:01 AM
        • KTM4012
          Cad Model Storage Location
          by KTM4012
          Hey Guys, when I import my cad model (step format), I pull it from a backed up drive from the engineering guys. My question is when I save the program...
          04-06-2022, 02:06 PM
        • Msolito
          CAD Model question ???
          by Msolito
          When I copy a program with Cad model , the program copy but the CAD model not , I only can copy or cut , any trick to do that , or I just need...
          02-27-2009, 12:13 PM
        • PCDEMON
          replacing a cad model
          by PCDEMON
          I replaced a cad model in an existing program (new revision) . Ran the program works ok . Problem occurs when I try to add new features
          02-12-2009, 05:12 PM
        • lost_in_endicott
          Weird CAD problem?
          by lost_in_endicott
          I"m really new to PC-DMIS. I'm having an issue with the CAD model representation disappearing from finished programs. I programmed a part Monday,...
          07-10-2019, 07:46 AM
