Our system is shutting down every time we open the graphics window. We open PC-DMIS in a very minimalized screen so that all you see are toolbars, then we turn off the graphics window, at this point you can open everything else to full size, the problem is every time you open the graphics window it shuts down PC-DMIS completely. We have tried everything "tech support"? has offered and even updated our graphics card to no avail. Any help would be greatly appreciated as we are dead in the water.
URGENT need of answers
It certainly sounds like a problem with the way your 'puter is handling the graphics. You say you "updated" your graphics card. Did you install a new card? Is it pc-demon friendly? Are the correct drivers installed? Do you have any other CAD based application you can try on the system? When did the problem start? What could have changed, (other than graphics card failing), between the last time it worked and the first time it failed? Sorry to only offer questions, but it is the only way I know to narrow it down.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
you maybe running out of virtual memory. are you running any other applications? I find pcdmis does all kinds of funky things when other applications are running.sigpicTHE TASK AHEAD OF YOU, IS NEVER AS GREAT AS THE POWER BEHIND YOU. I Fight for Freedom and Pray For Peace..
3.7mr3
Tim; Yes we have and it didn't work.
Wes; This is the only thing we use the computer for, no other apps, it had been working but crashed frequently fro the past couple of months so Tech support told us to upgrade our service pack from 2 to 4 and that would appear to be the catalyst. The video card we installed does have the correct drivers and is the same card we have on a similar system.James Temmen
Well, this may sound like a dumb question, but did you try a clean install of windoze with sp2and the new graphics card? Are you using ATI grapichs card? Which version of the demon? Did you try putting the old card back in? Is there any chance you could try a different computer? I am not an expert, but seems to me it could be something in the computer besides the graphics card, that is causing the problem, but I do not know what that would be.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Your ram may need to be pulled out and cleaned with an eraser. Try that. Occasionally, ram will corrode from a minimum of moisture. Try pulling it out and running an eraser across the gold contacts. Be sure to put them back in the way they came outsigpic
Originally posted by rebeldudeYour ram may need to be pulled out and cleaned with an eraser. Try that. Occasionally, ram will corrode from a minimum of moisture. Try pulling it out and running an eraser across the gold contacts. Be sure to put them back in the way they came out
by Measure GoodIs there a reason why PDCMIS has not worked with a specific Computer Graphics Card Vendor to "qualify a specific Graphics Card and its Driver updates"...
04-16-2007, 06:59 PM -
by Jasonleewhen i run PC-DMIS it lags so much. any suggestions on maybe uping the graphics card ?
10-28-2009, 12:49 PM -
by Lisa H.Just recently have been working with the new PC-DMIS CAD++2013 MR1. I am having problems trying to print from my graphics window. When I hit the print...
06-05-2014, 02:40 PM -
by rtlawlorSo my new Facility using PC-DMIS 2019, that I HATE with a passion, and when I try using PC-DMIS 2016-2014; IT LAGS SO HARD. I have 128gb of memory, and...
07-14-2020, 03:09 PM -
by Jonde1Good Evening CMM'ers!
I have installed Pc dmis 2014.1 on my new laptop and i am wondering on how to get the software to use the dedicated...-
03-11-2016, 02:11 PM -
