I'm using 3.7MR3....my partial execution from cursor or feature does not refresh measured data. Has anyone else had this issue?
Measurement Data
If you are executing individual features you have to click "yes' to the update nominals prompt.
When you execute from cursor, you should only get dimensions for whatever you dimensioned below the cursor if you marked them. Anything above the cursor you will not get refreshed or printed out.I used to be high on life but I built up a tolerance.
by Got-a-lifeVer 3.7 MR3........After executing program......I try a partial execute from cursor on a marked feature (i.e. circle)...to remeasure......it does not...
08-10-2006, 04:19 PM -
I believe I said no to save stats and it went to datapage anyway. Could this be or perhaps I may have said yes. Anyway does this happen? If so anyway...
Channel: DataSuite SPC
04-29-2009, 10:52 AM -
by tinabethRunning PCDMIS 4.1 and Datapage 3.33. Question is when I'm in a program and it ask to update data base, yes or no and I pick no .Close that program. Open...
05-18-2009, 05:10 PM -
by djone368how do I set up my program to prompt me at the end
"update data page now"
right now I have to send current...-
05-24-2007, 09:34 AM -
by rollbar0533Here is the scenario...
I am executing a program and I run into a situation where I need to change a feature for whatever reason (i.e....-
10-27-2009, 07:07 PM -
