Unlike most of you, I'm fortunate enough to get to change my probes manually. But sadly, this creates deviation in the measurements. I know that I could just recalibrate each probe before measuring the part, but there must be an easier way. Any thoughts on how to decrease the amount of deviation?
Probe Changing
Once you move the probe in some way, it needs to be recalibrated. Now it would depend on what tolerances you are using. I wouldn't worry about it if your tolerances were +/-.01".
Tell your boss to get modules for all the probes you use or get a changer rack.I used to be high on life but I built up a tolerance.
If you have to change probes manually (unscrew and re-install) in the middle of a program I would put a comment in stating which probe is needed. Then after that you can put in a command to calibrate the probe. If you keep your cal. sphere in one place it will go to it and calibrate automatically before progressing in the program.
Let us know if you need help programming this.
Originally posted by Matthew D. HoedemanIf you screw/un-screw ANYTHING, you need to re-calibrate.
What probe system do you have? The TP20's are great. If you get multiple modules you can just change quickly without reclaibrating. Or, try to program using a limited number of tips.When in doubt, post code. A second set of eyes might see something you missed.
I wonder if he is perhaps using an older probe head such as a PH9A, this type used a PAA adapter that the touch probe and tip stayed screwed into. I have this type right now and have no problem switching between different probe/tip configurations on the fly. I am not however, working in the micron world in terms of part tolerances.
TKsigpicHave a homebrew
Originally posted by Matthew D. HoedemanIf you screw/un-screw ANYTHING, you need to re-calibrate.v2013 MR1, v2015.1
B&S Global 544, 555
Mitutoyo A504 w/PC-DMIS
Since 1994
(Advice from my dad.)
by DmisDaveI have a TP200 and two modules with different probes attached. I would like to change probes in the program. It appears that I can use a Load Probe command...
05-14-2010, 01:29 PM -
by BIGWIG7big program that requires 3-4 (more or less) different probe builds and tips.
calibrate all the probes only to find out half way through...-
04-13-2015, 05:54 PM -
by thomasHello to all PC-DMIS for CMM folks,
I have been working crazy 12 hour days for several months now, I am in need of some guidance with some new...-
07-03-2009, 12:30 PM -
by ThresholdHi. I'd like to be able to calibrate the 4 different touch probes (for all the existing rotations) that are stored in my probe rack using a single program...
11-04-2009, 10:19 AM -
by Pat AhernHello all... Happy Holidays.
A customer wants me to run a program that includes probe changes using a Probe Changer. I don't have a...-
12-26-2007, 04:09 PM -
