Yesterday we switched from 3.5mr2 to 3.7mr3. Now I am having some slight scan issues. I remember from a user group meeting that there was a check box that needed to be selected in order for 3.7mr3 scans to comp the same as 3.5mr2. I believe that its the CAD Comp box, can anyone confirm that? Also what is the Use COP box in the lower left corner of the dialog box?? Ive check the help file for both the CAD Comp and the Use COP and there is no mention. Thanks
scanning questions
Cad-Comp
What type of scan are you using? Relearn, Defined....
What type of probe are you using SP600????
When Scanning with a SP600 the cad-comp will calculate the locations of the points at the tangent point of the probe to the surfaces.
If you are using a TP20, with a scan that is not relearned the cad-comp is not necessarily an issue because the probe comes in on the correct vector to the surface.
It is the Cad comp box.Last edited by Sean Harris; 06-21-2006, 11:05 AM.Badges..... We don't need no stinkin badges.
COP
COP - Cloud of Points......I know that this is used with laser scanning (handle large amounts of points more efficently). I have not heard if it is used with sp600 or tp20 scanning).
Going back to your original question......the cad-comp will not hurt using it for all scans...the algorithim used is slower, so results will be a bit slower in the coming.
You can use the datafield edit icon and do a global change in your program to turn the cad comp on in all of your scans. If you need help with that...let me know....
Tim
The datafield edit idea sounds like a good plan, I'll give that a try. Thanks
Last edited by Sean Harris; 06-21-2006, 11:44 AM.Badges..... We don't need no stinkin badges.
Hi
We are working with 3.7mr3 PCDMIS CAD and have been trying to perform a manual scan (that being the only option available in this version.)...-
05-08-2007, 09:05 PM -
by CNC MILLI am reverse Engineering my companies thermoform molds that do not have any documentation of what they are. I am scanning with a SP25 probe. When it scans...
04-12-2006, 11:17 AM -
by mange34I have a problem with scaning compared to a 3D part .
I want to scan the light blue surface as you can see on the pix i have instert....-
09-13-2007, 09:44 AM -
by The DudeOk, I have a .015 groove that the customer is looking for profile on, the groove has some curvature to it, and I am ready to simply hit "To Points"...
08-04-2008, 03:54 PM -
I need to reverse engineering a rectangular area at X=.1 by Z=.1 hard increments for the whole area. Anyone know the best scan for this?
03-27-2008, 07:23 AM -
