I have question. Here is what I have. I have a long cylinder(12.09") that has inside chamfers on it. I need to check the length and the inside diam. I am also checking the OD as a cylinder.
What I would like to know is:
If the length of the part changes by about .030" can I touch one end of the part to get a starting point so the probe will hit in the same location every time?
I will need to do this on both ends of the part. I am taking vector points on a chamfer on the inside so I can construct a cone and get the angle.
I could set up two different aligments if needed.
I programed with one part and it came out perfect but when I put a new part on it didn't hit some of the vector points to make the cone. I think the part is a bit shorter. It didn't go far enough into the ID cylinder to take some of the hits.
I have about 130 pieces to check and would like to do most all of it on the CMM so I don't spend all my time in front of the compartator.
I do not have any CAD for this one.
Thanks ahead of time.
3.5MR2
3.5MR2
