Runout calculation
  • Runout calculation
    We are trying to correlate the runout of a OD back to an ID using the CMM and indicator. I printed the text analysis of the runout for every point taken. It shows the actual X,Y,Z,I,J,K and deviation for all points. I see the max and min values in the deviation column and it adds up to the runout result. How is the deviation computed?
    We are using 3.7 Version
    Thanks,
    Runout
    Mathematical Definition of Dimensions
    The runout dimension determines the runout of the first feature with respect to the
    second feature (i.e., the second feature becomes the datum feature). If only one
    feature is selected, the origin of the current active alignment and the workplane
    vector define the datum feature. The text in the Edit window for the datum feature
    will read "THE ORIGIN".
    This option works for circles, cones, cylinders, spheres, and planes. This
    dimension type is considered one sided, meaning a single positive value tolerance
    The runout for circles, cones, and cylinders is the difference between the max and
    min radial deviation of the measure points from the datum axis. The runout for
    spheres is the difference between the max and min radial deviation of the measure
    points from the datum origin. The radial deviation of circles, cylinders and
    spheres is based on the measured radius of the feature. The radial deviation of
    cones is based on the radius at the cone height of each measure point using the
    measured angle of the cone.
    The runout for planes is the difference between the max and min deviation of the
    measure points from the plane formed by the feature plane’s measured centroid
    and the datum vector.
    For cylinders, cones, spheres and planes, the reported runout is the total runout.
    For circles, the reported runout is circular runout.
    THANKS (CAD IS ALWAYS MASTER)
    • VONDY
      RUNOUT vs CIRCULAR RUNOUT
      by VONDY
      In 3.5 We Had The Runout Dimension, But In 4.1 They Call It Circular Runout Dimension. I Have A Part That I Am More Or Less Checking The Face Runout...
      10-04-2006, 12:34 PM
    • FCGomes
      Runout and Total Runout
      by FCGomes
      No idea if anyone can answer this or not.
      I am having a problem with runout and total runout.
      When I measure features off a combined datum,...
      04-22-2009, 02:05 PM
    • JoBLOCK
      Runout
      by JoBLOCK
      Roughly speaking: runoutx2 = concentricity right?
      Example. round part. I am chucking on the OD checking the runout of the ID
      03-30-2009, 02:55 PM
    • keego
      Lateral Runout
      by keego
      I have a runout callout on a plane at the end of cylinder Datum_A. I constructed the plane from points taken using paste with pattern. When I select the...
      03-02-2010, 01:36 PM
    • PowerJunkie
      CAD feature has runout??
      by PowerJunkie
      Strangest thing... I'm used to models being perfect so when I see deviation it throws up a HUGE red flag.
      The requirement is Runout .001"...
      01-24-2019, 10:01 AM
