If I want to use thickness to project a profile, I need to use theoretical or actual (the problem is I have a gage and one of block is short 3.5mm (for profile purpose) and have a hole on it, and I need to find out if hole is the right x,y,z position but when I use Auto circle and take the 3 hit in the surface, and then add the 3.5 thickness the probe don’t find the surface stop 3.5 mm up any idea how to use Thickness Thank you in advance
