How do you use the pitch option for say 1/4-20 thread. What number would go in the pitch box and would you need more that 0 start and 360 end. Thanks for any help.
Pitch in Auto Circle
Pitch is the number of threads per inch, so for a 1/4-20 it would 1 divided by 20 = .05. I have always just used 0 and 360, but I almost always use a cylinder to measure a thread, not a circle. Someone posted recently that you should go more than 360, and I intend to try that sometime soon. With a cylinder, 360 gives good results. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
As was suggested in a previous thread going more than 360º can only improve your measurement. To use the feature just enter the pitch (1/threads per inch(1/20=.5 for 1/4-20)) of the thread. Also, I enter the minor diameter of the threads as the hole nominal diameter. Of course you want to make sure it is progressing the correct direction. I don't trust it yet so I enter a large pitch (.1), execute the hole and visually check that it moves in the correct direction. Then I F9 the circle and edit the pitch to the correct one.
Apparently Wes thinks and/or types faster than I do.
Originally posted by GoodluckAs was suggested in a previous thread going more than 360º can only improve your measurement. To use the feature just enter the pitch (1/threads per inch(1/20=.5 for 1/4-20)) of the thread. Also, I enter the minor diameter of the threads as the hole nominal diameter. Of course you want to make sure it is progressing the correct direction. I don't trust it yet so I enter a large pitch (.1), execute the hole and visually check that it moves in the correct direction. Then I F9 the circle and edit the pitch to the correct one.
Apparently Wes thinks and/or types faster than I do.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
Metric threads are different. For example a M20X1.5 would have the pitch of 1.5 you do not divide 1 by 1.5. Now, since most of my programs are in inches and I have some threads that are metric I usally convert the metric pitch to inches and carry as many digits as possible.
by AUH20Is there any information that one would like to offer a first time user concerning measuring a tapped hole?
I have picked up the circle...-
09-10-2009, 04:17 PM -
by SchlagI am a little confused on the PITCH FUNTION in an auto circle. I have programs from 2011 MR1 that I was able to use the "CIRCLE " function,...
02-05-2013, 04:21 PM -
by TigerSharkHi
I am trying to measure a threaded hole, I need use pitch, the problem is, when I input the Pitch value the circle will shift for...-
01-25-2008, 01:08 PM -
I've been asked to measure a pitch of a thread. I'm not sure how to do that, or if it's even possible?
05-16-2018, 01:07 PM -
by UnderspecI have a call out of .125 Pitch thread / 3.25 Revolutions. I've never measured this kind of feature on the CMM. From what I've been seeing is that it...
08-14-2006, 02:39 PM -
