Most of the time I don't have a problem with this command, however, for some reason, today the software will not allow me to construct a cone from 2 circles. The circles each have a 0,0,1 vector, they are both at 0 in the X and 0 in the Y, each is at a different height in the Z and they have different Ø's. As far as I can tell, there is nothing obvious (to me at least) that should prohibit PCDmis from contructing this cone......if anyone has an answer, I would love to hear it
Construct a cone problem
cones
If your still having trouble the best thing to do alot of times is what Mikey said.
I've wasted more time trying to find out why something isn't working. Than if I wrote the whole program again from scratch. Of course it depends on the size of the program and your skill level. Cones and Spheres can be tricky so give it time.
PCDMIS has alot going on in the background, things you can't see really see unless it was in pure DMIS. If reconstruction of the feature or features doesn't work save it as another name as backup. Always check your working axis and alignment first. Hit F5 and make sure you have Allow fine tune of Alignment.
Have fun________________________
DEA SCIROCCO-15-10-09
TUTOR P -4.2 MR1-XP
by c_beardenPCDMIS is not allowing me to construct a cone from 2 or 3 circles.....I am going to 3-different levels of a cone and measuring an 8-point circle at each...
02-14-2011, 02:14 PM -
by ROBB OVERBEYIs it possible to construct a cone from two circle's in a program? I have a part that i'm trying to find the diameter at a certain height on an angle....
08-14-2014, 11:38 AM -
by MIKEYIt won't let me costruct a cone out of 3 circles. strange.
05-05-2008, 10:37 AM -
by LikeCosmosHello I need your help once,
Functionally dependent on the element will not do, my 12 year old Mitutoyo software calculates internally to the individual...-
11-02-2012, 07:13 AM -
by SamsdadmattIm trying to construct a cone(auto) I'm selecting three circles but it tells me i cant do that. What do i need to construct a cone?
08-25-2016, 05:55 AM -
