A quick glance didn't show me PK1 on the Renishaw site.
Being a knuckle as stated, I take it that it is a manually oriented knuckle. If this is the case, unless you use pre-defined positions, like a star probe, you may have to calibrate all angles manually.
Calibrating tips using a pk1 knuckle
Using PH10MQ facing -x- minus direction on horizontal machine, rotated
to 90, -90, the pk1 is facing down in the -z- plus. Probe keeps calibrating
on the shank of tip. In probe file, probe looks to be in the correct direction.
Is there something we are missing?Tags: None
How can one utilize a 90 degree Probe Tip and calibrate. It would be like having only one tip attached to the star Probe Body at 90 degrees with the other...
07-19-2006, 05:33 PM -
by psalm2cant seem to get the paremeters right to calibrate and use 3mm probe 90 degrees on 0,0
08-22-2006, 04:46 PM -
by Addison WoodRunning a PH10MQ with an 30mm to 8mm converter, TP20, 20mm M2 extension, M2 Knuckle, and a 1X20mm probe.
When the PH10MQ is at 0,0 I want...-
05-09-2007, 01:03 PM -
by Otto SquareMy star probe file keeps on creating a T5_A90B180. It is not possible to calibrate it, so it crashes if I don't delete it.
Anybody else...-
05-12-2009, 01:25 PM -
by mdobb829Has anyone used a stylus knuckle with any success? What is the difference between a regular knuckle and a rotary knuckle? Is there anything that needs...
10-30-2010, 08:31 AM -
