Calibrating tips using a pk1 knuckle
  • Calibrating tips using a pk1 knuckle
    Using PH10MQ facing -x- minus direction on horizontal machine, rotated
    to 90, -90, the pk1 is facing down in the -z- plus. Probe keeps calibrating
    on the shank of tip. In probe file, probe looks to be in the correct direction.
    Is there something we are missing?
    A quick glance didn't show me PK1 on the Renishaw site.
    Being a knuckle as stated, I take it that it is a manually oriented knuckle. If this is the case, unless you use pre-defined positions, like a star probe, you may have to calibrate all angles manually.
