body alig. to print alig.
  • body alig. to print alig.
    I have a part that is in car body position, I do an iterative alignment, using features from cad not datum fratures,all is good. Part is set on a gage block for datum A(from print), my question is how do I get part to match print ABC
    Thanks
    Clay_Man , can you post the code or partial print
    Always Looking at the Big Picture :D:D:D
    3.7 MR1 CAD++
    4.3 Mr1 CAD++
    B&S (Global 07-10-07) -PH10T/TP20
    B&S (Microxcelpfx) -PH10MQ/TP20
      The way I normally do this is after the iterative alignments I measure the datums per the print and create a new alignment.
      DeWain Hodge
        Put the model in print position!!! JC
        Jeremy Cavender
        CMM Metrology Engineer
        PC-Dmis 3.2/2010/MR2
          If you did both manual and DCC iterative alignments (per Cad) you could
          finish checking all the features and before recalling dimensions create the
          ABC alignment per print.
          Otherwise you can do the ABC at the begining right after the manual iterative.
          No difference.
          sigpicIt's corona time!
            Originally posted by dewain hodge View Post
            the way i normally do this is after the iterative alignments i measure the datums per the print and create a new alignment.
            1+
            THANKS (CAD IS ALWAYS MASTER)
              Thanks I will get our cad guy to put it in print position
              CLOSED
                If you want to, buy you don't have to.
                (Upss is closed...sorry)
