I need to check the true position of a 4 holes in the x & y direction. The feature is a RFS, however you have a MMC on the -A- datum. I dimensioned the feature with an RFS on the Feature and a MMC on the -A- datum. However I don't believe the bonus tolerance calculates correctly. It is a 48.54 inside dia. +0/-0.18. The diameter checks 48.54. The bonus tolerance changes for each hole. It is given me bonus tolerances of .07, .09, .10 & .07. Shouldn't they be the same since their is only 1 -A- Datum and shouldn't it calculate to 0.18 bonus tolerance?
Bonus Tolerance of a TP
Search this forum for MMC and/or Trueposition, you will find volumes of detail about what the demon is doing to you and how to work around it. CraigerNY posted a workaround using varriables that is probably worth looking into. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
As long as you are only checking 1 modifier box ( material conditions) in your true position dimensioning box i would think it would calculate correctly. I run 3.5 mr2 and when you check multiple boxes it does not calculte all the bonus.sigpic.....Its called golf because all the other 4 letter words were taken
version 4.2 mr1
I am checking the location of a hole pattern @ .020 mmc to datums A,B,C
D1 - (plane) RFS (A)
D2-...-
03-03-2008, 11:52 PM -
by dph51v4.1
Using legacy dimensioning
I am trying to dimension a feature TP with double bonus.
|TP|0.7 @mmc|-B- @mmc|-C- @mmc|...-
07-14-2010, 01:10 PM -
by kalepitoI need report true position of .010 hole of d.1285 .132 on mmc about A and B(hole of .1285 .132) on mmc
but the cmm show me a bonus tolerance...-
02-22-2010, 07:55 PM -
by PacMan23I am dimensioning true position of a few holes, the diameters are out of tolerance (to big) so should they still benefit from the MMC and gain that Bonus...
Channel: PC-DMIS Portable
07-20-2017, 05:10 PM -
by dcossI'm running a program that I am reporting out true position for three holes. If you look at the report, it is showing them out of tolerance, but it doesn't...
12-30-2022, 10:05 AM -
