OK, I'm going to try and get through this without a rant but I'm frustrated.
3.7mr3, I'm trying to measure a cylinder. It sticks straight up out of a block 15 mm and is 8 mm in dia. I can't use clear plane due to location and alignment. I have all the correct things marked, stud, height, dia, # hits, depth, etc. I have initial, perm and spacer at 0, although I've tried various configerations. I take 3 hits on the block surface and the 6 hits (3 on 2 levels), on the cylinder. When I tell it to measure, the probe goes right to the center of the stud and straight down. Fortunately it is a bushing and it doesn't crash. I just get an unexpected probe hit. Even the graphics screen, if you click on the little green pointers, has the probe going to the center.
WHY!!! This should be a no-brainer, but it is Monday and maybe I'm missing something. I've attached a screen shot of the pop up. Hopefully, I'm just full of stupid this morning.
Also, once I click off the clear plane box, why oh why does it keep coming on every dang time I F9 the cylinder to see if something is off. I've already made one fishhook this morning because of this.
