Hello again, I'm running 3.7 on a B&S "One". This machine is made for the machine floor so I can have multiple users. I have many programs written so the operators can locate their part and hit "Go". Here's my situation. On my "edit program" page, I have all my dimensions at the end of my programs, after the part has run, I have to go through and edit my dimensions, (usually just by deleting the last digit of my dimension) and stepping down to the next dimension. This is very time consuming and a real pain in the butt. I have had the training supplied by B&S, but was never taught how to do any reports, Plus the cost of paper is to high!!! LOL Imagiune that!!! Help Please. Is there a way to set my reading to change after I run a part? Thanks in advance.
Data Page
On my Edit Page (Program), I select the dimensions that I want to view
I Have a dimension like this:
Dimensions Nominal Measures
X=.500 +.005 -.005
Y=.750 +.005 -.005
D= .120+.005 -.005
After I run the part I get something like this:
X= .4998+.005 -.005 .4988 .4988
Y= .7503+.005 -.005 .7503 .7503
D= .1196+.005 -.005 .1196 .1196
I then have to go into the edit page and at the bottom where I have these dimensions called out. I always have to go into there and change the:
.4998 TO .500
.7503 TO .750
.1196 TO .120
This changes my dimension readout to the acutal measurement
Is there something I'm not doing?
Where can I change my program so I don't have to do this after every part on every dimension? Thanks
Are you useing CAD if so you may have the find noms turned on.
in the part program once you change them it should ask you if you want to update the noms.. answer yes it should keep them there.sigpic
Thanks this helps with my nominals.
After I say yes to update nominals, they stay to what I want.
But, when I rerun the part or even another part, I have to reset my Nominals to get the actual measurement readings to change. No 2 parts are the same.
Does this make sense to you?
I'm talking about the edit page. Not a report. Thanks again. I'm in real need of help!
Any suggestions?
It is an ITERATIVE alignment thing in V3.7 MR3. If you have an iterative alignment, after you finish running the program, you have to type in the FEATURE ID for the first dimension in the program, then they will all update to the 'current' measured values.sigpic
by Max TastyHi all,
Is there a way to cut and paste all the dimensions in a report and put them at the end? I've inherited a lot of programs with dimensions...-
04-13-2018, 10:04 AM -
by jpesaturoWe've recently been experiencing problems with some (but not all) dimensions changing on our reports. So when the program is first generated I change...
09-01-2016, 01:48 PM -
by DOUG MORTONFriday we had "mean" line of thunderstorms blow through North Ala. and we lost power. After re-starting my system (running 4.1), all of my page...
07-21-2007, 12:32 PM -
by derrickcoyneI have a cylinder that we're trying to dial in, and our machining tech showed me a report yesterday where the nominal was different than what was expected....
12-03-2019, 11:39 AM -
by rebeldudeGood Morning Everybody!
I got a question, first I need to tell you, when we program a part for checking, we have to put in trim check points about...-
04-21-2006, 07:10 AM -
