I keep trying to open up Pc-dmis, and all I can get is a little error window saing that there in an "Emergency Error". The only options I have are two buttons, "OK" and "Shut Down". But every time that I het "Ok", the window just pops up again. Any ideas for what I should do?
PC-dmis Error Message
Check and make sure that the E-STOP button on the joy-box is not depressed (and I don't mean sad!). If it is, you need to twist in (turn it) in one direction or the other until it pops back up.sigpic
error
You might also check the port lock my I.T. person was messing with my computertwo weeks ago and dislodged my port lock and I got the same
error with the same results. until I stumbled across the loose port locksigpicTHE TASK AHEAD OF YOU, IS NEVER AS GREAT AS THE POWER BEHIND YOU. I Fight for Freedom and Pray For Peace..
Originally posted by Paul SarrachMy money is on the estop.Originally posted by Paul SarrachThats the first thing I do, no matter what the problem. Its amazing how many problems a reboot and cure.
by Matt TalbotHello All,
New to CMM world and PC-DMIS. I am using V2019 R2 on a 9158 Global S Green. When i started up PC-D I got this message "Error...-
02-03-2021, 11:44 AM -
by Big JeffersWhen I Open Up Pcdmis I Get An Error Message Saying "communications Interrupted-attempting To Resynchronize".i Have Checked All The Connections...
08-18-2007, 06:22 AM -
by Mike RuffWithin the last few days, one of our CMM's has been throwing this error. I don't know what it means, but it won't just let me push the Machine Start button...
05-09-2018, 12:29 PM -
by dennisgilpinI have posted this before and got good responses about some sort of communication error. This has happpened once a year (different times in the year)...
08-08-2014, 11:24 AM -
by DeWain HodgeI started getting an error message during a circular move "ERROR CE ,S%1 ,TR_CE , 0x1400003a System error pushing a point in an" I can't see...
08-14-2020, 01:17 PM -
