Does anyone know how I can pass a feature / dimension / measurement from PC-DMIS to a VB Script and access it's measured value / tolerances / deviation / etc in the script? I have been able to pass numeric and string parameters, but not geometric objects.
Passing Features to VB Script
try this
Instead of passing features into a script, I use the script to find the feature and extract the data I need. Here is one example (assuming certain declarations are in place for the script). . .
For Each cmd In cmds
If cmd.IsFeature And cmd.ID = "PLN1" Then
MX = cmd.GetText(MEAS_X, 0)
MY = cmd.GetText(MEAS_Y, 0)
mz = cmd.GetText(MEAS_Z, 0)
MI = cmd.GetText(MEAS_I, 0)
MJ = cmd.GetText(MEAS_J, 0)
MK = cmd.GetText(MEAS_K, 0)
End If
Next cmd
Thanks,
I think that will get me by, but in general, I wish there were a better
way to pass a feature to a vbscript. It seems pretty inefficient to have
to loop through everything to find the one thing you already have a
handle on in the PC-DMIS code.
A little detective work convinced me that I can pass a feature as a
parameter to a vbscript, but it gets there as a 'Dispatch' object type,
and I do not know how to access it's properties. Not being a VB guru,
I'm not sure what to do with a 'Dispatch'. I'm probably digging a little
deeper than I should at this point, but like I say, passing a feature
to a script seems like it would be a handy thing to be able to do.
If you have any experience with a 'Dispatch' or run across a better way
to pass features, please let me know.
Thanks Again,
Dana
What exactly is your goal? If you are passing strings can you not use an assignment in PCDMIS to capture the feature data and pass that as a string? What are you passing to? Another app? An app you wrote? I pass info back and forth between PCDMIS and apps that I wrote in VB. I find that writting data to a text file and reading it in to be very flexable. When you hard code an app declare an array. Then all you have to do is read in from a text file to that array. I do it like this because I can modify how much info I pass without having to modify the declarations in my app. I'd like to know what you are doing exactly because I believe I stand to learn something here. What is your code for passing strings back and forth and what are you doing with it? I'm interested.<internet bumper sticker goes here>
by DaSaloI want to write a script that will locate a group of constructed sets and write the point data from each out to an external file. I already have a robust...
Channel: PC-DMIS Code Samples
08-19-2014, 09:17 AM -
by jvwhyHi All,
I hope this makes sense.
Is there a way to pass a variable to a basic script when it is called from a PCDMIS program?...-
09-09-2014, 01:21 PM -
by kaikaiI am new to PC-DMIS script. I am trying to read the script examples in the “Wizards” folder that comes with the installation. However, they are all...
06-09-2017, 02:44 PM -
by MykelHi guys.
I'm in the need of your help - again.
The users (operators) of the programs tips in on which machine the parts have been produced....-
10-04-2015, 05:58 PM -
I'm trying to pass a variable for work orde number from pc-dmis user input
C2 =COMMENT/INPUT,NO,FULL SCREEN=NO,
06-05-2018, 02:03 PM -
