Add a BASIC SCRIPT to your toolbar
  • Add a BASIC SCRIPT to your toolbar
    This should be simple and easy, but as always the help doesn't help. I'm trying to add a toolbar button to run EXCELSCRIPT.BAS (test32.xls). I can create a tool bar but I can't for the life of me figure out what I need to do to add a button to load and run the script. Any and all help is appreciated.
    Bill
    Bill
    try this
    How to set up tool bar in Pcdmis
    Right button click on tool bar you will see the above drop down menu.
    Click on the Customize option
    You will then get this menu click center tab Toolbars
    In the center colum of buttons click new and then toolbar and give it a name
    You will then go back to that same menu.. Click New again but this time click Item
    Click the 3 dots next to command line
    Next you may have to change the type of file from a .exe to .bas
    Point the path to your c drive and the EXCELSCRIPT.BAS file
    Info the TEST32 and the EXCELSCRIPT.BAS must be located at
    C:\test32.xls and c:\ EXCELSCRIPT.BAS
    For the script to run
    Make sure you hit the apply button and you should see the new toolbar.
    After you have some dimensions click the button on toolbar to open excel.
    I do not have it do it auto I click it myself.
    If you did not have an icon you should get a blank square in toolbar So surf around till you find one you like.
      Thank you, I'll give it a shot.
      Bill
      • Ekneel28@gmail.com
        Creating "Icons"
        by [email protected]
        How To Create Buttons "ICONS"
        Today I learned how to create my own personal icons
        and I wanted to share it with you guys.
        12-09-2018, 10:48 PM
      • bharpold
        Trouble adding icons to toolbar
        by bharpold
        Try this. If you right click by your toolbar, if should have toolbars listed and at the bottom should be customize. After you right click look and see...
        01-18-2009, 08:05 AM
      • Steve R
        The tool bar
        by Steve R
        Hi everyone, I have a simple question, how do you get the comment and clearplane on to the tool bar?
        06-01-2017, 09:02 PM
      • Gary Fitzgerald
        Setvals.bas
        by Gary Fitzgerald
        Trying to have this script executable on the toolbar. Is this possible in 4.2???Wilcox website has the srcipt and readme states how to link to toolbar...
        05-15-2008, 09:01 AM
      • chivasr1
        icons
        by chivasr1
        I was trying to remember how to get out a icon on my toolbar. I was using pcdimis 4.1 but now am using 4.3 and I was thinking you left clicked and draged...
        02-23-2010, 08:48 AM
