help please
  • help please
    Good Morning fellow programmers:
    I'm having a serious problem with my program using version 3.5. Every time i run a program everything changes. The cylinder is moved the points are no longer on the part, i get error messages telling me that the cylinder can not be constructed because of intersection. The coordinates are still good, but the probe is not hitting on the part. If it doesn't touch i end up reconstructing the feature. I really dont know what is going on. It may be a programmers or operators mistake. Anywho i am the one suffering. Does anyone have any suggestions on what needs to be done. I willing to try anything at this point.
    Thank you
    CFranklin
    well without seeing the program we can't help you. is the problem only with the cylinder?
      Thank you
      CFranklin
      Post the Program (edit window) so it can be trouble shot?
      sigpicThanks a Millionth
        this is the code from when i start to have problems
        MOVE/POINT,1.6135,-0.5999,2.9644
                    WORKPLANE/ZPLUS
        POINT1     =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/0.7283,-0.3684,2.0694,0.6621077,0,0.7494087
                    ACTL/0.7114,-0.3684,2.0502,0.6621077,0,0.7494087
                    TARG/0.7283,-0.3684,2.0694,0.6621077,0,0.7494087
                      THEO_THICKNESS = 0, RECT, SNAP = YES ,$
                      AUTO MOVE = NO, DISTANCE = 0, RMEAS = None ,$
                      INIT = 0, PERM = 0, SPACER = 0
        POINT21    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/0.3941,-0.3826,2.272,0.3583022,0,0.9336057
                    ACTL/0.3768,-0.3826,2.2269,0.3583022,0,0.9336057
                    TARG/0.3941,-0.3826,2.272,0.3583022,0,0.9336057
        POINT22    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/0.0434,-0.3863,2.3441,0.0394009,0,0.9992235
                    ACTL/0.041,-0.3863,2.2821,0.0394009,0,0.9992235
                    TARG/0.0434,-0.3863,2.3441,0.0394009,0,0.9992235
        POINT23    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/-0.1613,-0.3642,2.3331,-0.1466972,0,0.9891814
                    ACTL/-0.1369,-0.3642,2.1683,-0.1466972,0,0.9891814
                    TARG/-0.1613,-0.3642,2.3331,-0.1466972,0,0.9891814
        POINT24    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/-0.415,-0.3791,2.2637,-0.3772969,0,0.9260924
                    ACTL/-0.3958,-0.3791,2.2166,-0.3772969,0,0.9260924
                    TARG/-0.415,-0.3791,2.2637,-0.3772969,0,0.9260924
        POINT25    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/-0.6593,-0.3739,2.1255,-0.5993118,0,0.8005157
                    ACTL/-0.6413,-0.3739,2.1014,-0.5993118,0,0.8005157
                    TARG/-0.6593,-0.3739,2.1255,-0.5993118,0,0.8005157
        CYL4       =FEAT/CYLINDER,RECT,OUT,LEAST_SQR
                    THEO/0.0001,-0.3743,1.2446,-0.0052116,0.9999863,0.0005801,2.2008,0.0232
                    ACTL/-0.0008,-0.3644,1.2481,-0.0048757,0.9999504,-0.0086892,2.2007,0.0232
                    CONSTR/CYLINDER,BF,POINT1,POINT21,POINT22,POINT23,POINT24,POINT25,,
                    MOVE/POINT,-0.4951,-2.055,2.6015
        CYL1       =FEAT/CYLINDER,RECT,OUT,LEAST_SQR
                    THEO/0,7.5202,0.6696,0.0000231,-0.0000014,1,16,0.7472
                    ACTL/-0.0006,7.3972,1.0971,0.0021398,-0.0537424,0.9985525,15.8324,0.7478
                    MEAS/CYLINDER,6
                    HIT/BASIC,-1.0359,-0.4125,0.7068,-0.1294861,-0.9915812,0.0000016,-1.0395,-0.441,0.7114,USE THEO = YES
                    MOVE/CIRCULAR
                    HIT/BASIC,-0.6123,-0.4563,1.0432,-0.0765429,-0.9970663,0.0000004,-0.6158,-0.5039,1.0476,USE THEO = YES
                    MOVE/CIRCULAR
                    HIT/BASIC,-0.5599,-0.4602,0.296,-0.069987,-0.9975479,0.0000003,-0.5604,-0.4679,0.3006,USE THEO = YES
                    MOVE/CIRCULAR
                    HIT/BASIC,0.178,-0.4778,0.9559,0.0222483,-0.9997525,-0.0000019,0.179,-0.521,0.9602,USE THEO = YES
                    MOVE/CIRCULAR
                    HIT/BASIC,0.1873,-0.4776,0.333,0.0234134,-0.9997259,-0.0000019,0.1876,-0.4872,0.3375,USE THEO = YES
                    MOVE/CIRCULAR
                    HIT/BASIC,0.9494,-0.4233,0.7206,0.1186702,-0.9929337,-0.0000041,0.9528,-0.4528,0.7249,USE THEO = YES
                    ENDMEAS/
        POINT20    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/0,-0.4786,1.245,-0.0186005,-0.999827,0
                    ACTL/-0.0011,-0.5387,1.245,-0.0186005,-0.999827,0
                    TARG/0,-0.4786,1.245,-0.0186005,-0.999827,0
                    MOVE/POINT,0.5572,-1.9749,2.8111
        POINT14    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/-0.6897,-0.4445,1.546,-0.0861973,-0.9955684,0.0375988
                    ACTL/-0.6961,-0.518,1.5488,-0.0861973,-0.9955684,0.0375988
                    TARG/-0.6897,-0.4445,1.546,-0.0861973,-0.9955684,0.0375988
        POINT15    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/-0.2596,-0.4367,2.0345,-0.0324996,-0.9945865,0.0986987
                    ACTL/-0.2628,-0.5354,2.0443,-0.0324996,-0.9945865,0.0986987
                    TARG/-0.2596,-0.4367,2.0345,-0.0324996,-0.9945865,0.0986987
        POINT16    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/0.2333,-0.4709,1.5463,0.0291989,-0.9988625,0.0376986
                    ACTL/0.2333,-0.4709,1.5463,0.0291989,-0.9988625,0.0376986
                    TARG/0.2333,-0.4709,1.5463,0.0291989,-0.9988625,0.0376986
        POINT17    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/0.5928,-0.4244,1.977,0.0741033,-0.9930437,0.091504
                    ACTL/0.5928,-0.4244,1.977,0.0741033,-0.9930437,0.091504
                    TARG/0.5928,-0.4244,1.977,0.0741033,-0.9930437,0.091504
        SPH2       =FEAT/SPHERE,RECT,OUT
                    THEO/0.0004,7.5307,1.2447,0,0,1,16
                    ACTL/0.1281,7.4634,1.6719,0.0016121,-0.0601444,0.9981884,16.0365
                    CONSTR/SPHERE,BF,POINT14,POINT15,POINT16,POINT17,,
                    MOVE/POINT,-0.0245,-1.4232,2.5535
                    MOVE/POINT,-0.5593,0.7349,2.748
        POINT13    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/-0.3647,-0.1882,0.9033,0,0.9945246,0.1045026
                    ACTL/-0.296,-0.2266,0.8829,0.0090364,0.9864004,0.1641118
                    TARG/-0.3647,-0.1882,0.9033,0,0.9945246,0.1045026
        POINT18    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/0.3062,-0.1964,0.981,0,0.9945246,0.1045026
                    ACTL/0.375,-0.2444,0.9587,0.0090364,0.9864004,0.1641118
                    TARG/0.3062,-0.1964,0.981,0,0.9945246,0.1045026
        POINT19    =AUTO/SURFACE POINT, SHOWALLPARAMS=YES
                    THEO/-0.0227,-0.2675,1.658,0,0.9945246,0.1045026
                    ACTL/0.0465,-0.352,1.6311,0.0090364,0.9864004,0.1641118
                    TARG/-0.0227,-0.2675,1.658,0,0.9945246,0.1045026
        PLANE6     =FEAT/PLANE,RECT
                    THEO/-0.0271,-0.2174,1.1808,0.0000558,0.9945276,0.1044746
                    ACTL/0.0418,-0.2743,1.1576,0.0079561,0.9867996,0.1617503
                    CONSTR/PLANE,BF,POINT13,POINT18,POINT19,,
                    TIP/T1A0B0, SHANKIJK=0.0033, 0.0248, 0.9997, ANGLE=91.1494
        PLANE8     =FEAT/PLANE,RECT
                    THEO/0,0,1.245,-0.0001084,-0.0000571,1
                    ACTL/0.0162,-0.0611,1.2338,0.0002953,-0.0591994,0.9982461
                    CONSTR/PLANE,OFFSET
                    ID = PLANE1,,
                    OFFSET = 0
        LINE6      =FEAT/LINE,RECT,UNBND
                    THEO/-0.0135,-0.2241,1.245,1,-0.0000675,0.0001084
                    ACTL/0.0281,-0.2845,1.2206,0.9999682,-0.0079367,-0.0007665
                    CONSTR/LINE,INTOF,PLANE6,PLANE8
                    MOVE/POINT,-3.1076,0.4959,1.5264
        Last edited by Matthew D. Hoedeman; 10-01-2008, 09:24 AM. Reason: added the coding marks so it would show as Pcdmis code
          if you need the alignment i can also post that
            can ypu explain what are you trying to do real quick?
              First your ijk are not cleaned up, 2nd you constructing a sphere with 4 pints? A partial print would be nice. why are you using surface points? I got too many questions..
                WORKPLANE/ZPLUS
                CONSTR/CYLINDER,BF,POINT1,POINT21,POINT22,POINT23,POINT24 ,POINT25,,
                MEAS/CYLINDER,6
                MOVE/CIRCULAR
                MOVE/CIRCULAR
                MOVE/CIRCULAR
                MOVE/CIRCULAR
                MOVE/CIRCULAR
                ENDMEAS/
                CONSTR/PLANE,OFFSET
                ID = PLANE1,,
                OFFSET = 0
                this way to see better
                  MEAS/CYLINDER,6
                  MOVE/CIRCULAR
                  MOVE/CIRCULAR
                  MOVE/CIRCULAR
                  MOVE/CIRCULAR
                  MOVE/CIRCULAR
                  ENDMEAS/
                  You are constructing a cylinder with 6 points only? And a 15º arc?
                  No bueno!
                  The demon may say not enough data.
                  sigpicIt's corona time!
                    Roberto is right perhaps you need 3 levels to do a cylinder.
                      i really dont know how to post the print ... but im trying to get rid of that 15 degrees on the cylinder. How do i clean up the vectors
                        i have a part with a 6 degree plane, the top is a radius of 1.1, there are radi on both sides, there is a cylinder and a sphere on the back. Its just very complicated to me because i just started programming and i got the crash course on it... lol
                          the thing about the cylinders are that they are act ually radius
                            I am a visual person, so trying to explain to me it won't work. Anyway here is what I want to ask you are you sure that pnt 1 is part of that cyl 4?? because the ijk's are very different
                              Originally posted by c[color="red"
                              franklin[/color];189533]good morning fellow programmers:
                              I'm having a serious problem with my program using version 3.5. Every time i run a program everything changes. The cylinder is moved the points are no longer on the part, i get error messages telling me that the cylinder can not be constructed because of intersection. The coordinates are still good, but the probe is not hitting on the part. If it doesn't touch i end up reconstructing the feature. I really dont know what is going on. It may be a programmers or operators mistake. anywho i am the one suffering. Does anyone have any suggestions on what needs to be done. I willing to try anything at this point.
                              Thank you
                              cfranklin
                              are you by any chance that franklin from the show??
