How much in your opinion, damage can be done if any, if the air shut off while cmm is running?
No air
I wouldn't have thought that any damage will occur. The CMM will lock up to prevent damage, kinda like the air brakes on a truck. The air keeps the brakes off.If I have offended anyone with this post, I'd like to take this opportunity to say BOLLOCKSDry your eyes Princess and man up.
It would depend on IF the pressure locks are properly set. If someone monkeyed with them to get the machine running when the pressure was low (or if they broke), then I could see some damage happening. If the pressure locks are set properly, when the pressure drops below minimum (or minimum +5), then it shuts off the motors, locks the column and just sits there.sigpic
Originally posted by Matthew D. Hoedeman View PostIt would depend on IF the pressure locks are properly set. If someone monkeyed with them to get the machine running when the pressure was low (or if they broke), then I could see some damage happening. If the pressure locks are set properly, when the pressure drops below minimum (or minimum +5), then it shuts off the motors, locks the column and just sits there.
Originally posted by Goodluck View PostRight, it should be able to run without damage (air bearings maintain adequate clearance, etc.) at a pressure lower than that at which the air locks (brakes) are set. So, it should not suffer any damage if air pressure were to drop while the machine is running. I'm assuming it isn't an instantaneous drop from running pressure to zero. If it was instantaneous, theoretically damage could occur because the point in time where the locks engage and when the pressure is zero (zero clearance for air bearings) is the same instant.sigpic
Depends on the machine. Had one that had the air shut off and the machine didn't stop. Killed the x-axis motor. It was an old machine and no spares on hand. $10k's and months later we finially had the machine fixed. Installed a backup compressor and pressure warning light right after...Saving the world, one bad part at a time.
We had it happen a couple of times with no damage on our LK & Mitutoyo machines. I was usually the first one to notify maintenance that an air compessor was down because the CMM would lock up or I would hear one of the air bearings start to rub the granite. Adding a hold up tank helped with the pressure going down gradually instead of all at once.sigpic
Originally posted by justncredible View PostI seen a validator that the Z would fall when the air died. Every nite we had to park it on a foam cushion. That thing must have been 20 years old, big huge keyboard thing.sigpic
by danthecmmmanHow many pounds of air pressure coming in off the air line do you need to have the CMM run? Currently i need my air gauge to read 90 pounds coming in...
08-22-2018, 12:04 PM -
by hanssHi guys and hello, today my machine (B&S global) started making a pressured air sound while moving up in Z. It only happened for about 10 minutes,...
02-09-2011, 08:44 AM -
by rsegriggyWe've got a Global 9-12-8. Yesterday, the power failed here. The z-rail came down and the probe hit the granite. There is a battery back-up (appropriately...
07-14-2010, 10:39 AM -
I have an air pressure fault or lube fault error. I have air supply to the CMM but I can't get the machine to start. What's next? Currently running M...
08-20-2007, 11:14 AM -
by gppcdmisIn the past two weeks my machine just stopped and I heard the air switch on the CMM just shut off and went on with in couple of seconds. I watched the...
03-29-2010, 12:47 PM -
