I can not figure out why my machine keeps crashing into the calibration sphere. I have a PH10MQ and am running 3.7mr3 I can start a new program and calibrate an A0B0 probe after I tell it that the sphere has moved, take a hit and it runs normal. Then with this same new program, if I change the probe file to just a different length probe and say the sphere has not moved, the probe will come down and probe the sphere about .150 off center.
On my machine, I do not move the calibration sphere, hardly ever. I have the same probe files on the C drive that I have been using for years. The probe head is square to the machine axis with in about .025 over one foot.
I can calibrate a A0B0 probe after taking the single hit. Then go back into probe calibration tell it to calibrate a 0,0 probe and add in some angled probes, it will calibrate the 0,0 OK and then probe the angled probes off center (crashing all the way).
Please do not suggest that I increase the pre-hit. Something has changed and increasing the pre-hit is not the way to fix it, that is only a work around. I have asked this once before and did get anything from the previous post that really helped. I did keep the probes files in shared directory before but moved them onto my C drive per a previous post suggestion (no help).
