I started off on DOS as well. The software sure has come a long way! I remember I was so impressed when you were first able to make CAD solid. I used to go so buggy staring at the wireframe all day!
sigpic GO LEAFS GO!!!
Stay true to your friends, 'cause they'll save you in the end.
-Sam Roberts
HeII, I STILL have it. I do not use it, in fact, I posted not too long ago on this board about directory structure and dug up some old DOS versino programs to show them what Pcdmis did back then and why it was so DANG important to have a rigid, well defined directory structure so you could keep tab on the programs.
In fact, I could run it today if I wanted to, all I need do is take out the archive CD and copy all the stuff back to the hard drive and I would be ready to go. Heck, I still remember the CODE for checking parts using VAL-MEAS 200 (YUCK).
I started with OFI3PLUS, upgraded to Avail, upgraded to MMIV, switched to Valisys, and finally switched to PCDMIS 3.5Mr2 a lil' over two years ago. It's been a lot of fun and at times a real PAIN IN THE **** over the past ten years...
PCDMIS 2012
Windows Office XP
I started on Geomeasure on a Mitutoyo Bright. Then made the evolutionary leap to LKDMIS - That maybe why I don't feel that the bugs in PCDMIS are so bad.
We currently installed Version 4.0 on 3 of our machines and although it has some tremendous capabilities it is plagued with bugs. Square Slot Auto Feature...
I am replacing 2 workstations that have 3.5mr2 on them with 2 better workstations that I must put 3.5mr2 on. During the install process, after I accept...
Well, we actually talked the higher ups into getting a new high speed, powerfull computer and although I know this has been covered before on the forum,...
