Surface Point versus Vector Point
  • Surface Point versus Vector Point
    What are the advantages of Surface Points versus Vector Points?
    sigpicThanks a Millionth
    More hit data all depends on what you are trying to accomplish I perfer vector points any day there is times you need to use surface points. JC
    Jeremy Cavender
    CMM Metrology Engineer
    PC-Dmis 3.2/2010/MR2
      There is ABSOLUTLY NO difference between a VECTOR point and a SURFACE point WITH NO SURFACE SAMPLE hits. They are the same. IMO, the surface point is for points that you have no true data for (xyz or ijk). The use of the 3 sample hits calculates the REAL vector so that Pcdmis can comp the probe correctly. You might also want to use them for excessivly tight tolerance, like on the order of +/-0.010 MICRONS (not thousandths).
        Have they fixed the Surface Point bug in the 4.X releases? Surface Points didn't keep the thickness settings from one run to the next and I hadn't heard that it was fixed although it's been long enough that I suspect that it has been.
        Bill
          So the diff. is you can have sample hits with surface points vrs vector this would have more hit data. But as Matt has stated if you do not use sample hits there is no diff. depends how they are used. JC
          Jeremy Cavender
            That's a little mis-leading, there will not be more hit data, that is still only ONE point from a vector point and one point from a surface point. you will not get 4 points from a surface point that is using 3 sample hits.
              Vector points will approach the part always from the nominal vector every time.
              Surface points, with surface hits, will adjust the approach vector normal to the surface depending on the vector of the surface.
              sigpic GDTPS - 0584
                Only if you've taken a minimum of 3 sample hits. It will then correct for a calculated approach vector based on the sample hits. Surface points will take approx 4 times as long to run as vector points IF you use the sample hits.
                Bill
                  This q. was brought up so many times.
                    Originally posted by matthew d. Hoedeman View Post
                    there is absolutly no difference between a vector point and a surface point with no surface sample hits. They are the same. Imo, the surface point is for points that you have no true data for (xyz or ijk). The use of the 3 sample hits calculates the real vector so that pcdmis can comp the probe correctly. You might also want to use them for excessivly tight tolerance, like on the order of +/-0.010 microns (not thousandths).
                    +1
                      What's your point Mikey? Should we quit answering this question because it's been asked so many times or should we continue to help people that come here looking for answers and assistance?
                      I'm just wondering what your point is.
                      Bill
                        and now for a little history lesson.
                        Years ago when the controllers couldn't drive a good "vector", there was a difference between them. Surface points always had sample hits and vector points did not. Vector points were wuicker to execute, but not usually as accurate. If you wanted accuracy in vector compensation, you would sacrifice the time to use the surface point. These both came out of a standard (from GM originally, I believe) that included circle definitions as well, but not much more.
                        Now this whole sheet metal philosophy includes many more features, and sample hits are fully configurable in all features. And since the machines can pretty well drive straight vectors, sample hits are less often needed, and the difference between Vector points and Surface points is becoming more clouded.
                          Well, my point is this: it could be looked up in the search, b/c there is prob. about 15 threads about this.
                            Bill
                            You are correct.
                            sigpic GDTPS - 0584
                              Well then, smart guy, how am I supposed to pad my post count then? Hmmmmmm
                              sigpic GDTPS - 0584
